The previous owners have cut the power line going to the lubrication pump. Can anyone tell me which color wires go to the motor and which to the switch? I will also need to know how and where the cable gets routed and to which connections it needs to get power from. The schematics are not clear. Thanks! |
So this post influenced me to go out and get my lube pump working. I found that the black and white are in fact 110v supply and return. On my machine I could get no connection between red and green so I opened up my junction at the pump. I found the green wire was not connected. The actual pump has 5 wires, Blue, White, Red, Pink and Pink The blue wire is hot and was connected to the black wire. The white wire is neutral and connected to the white wire. The red wire was not connected but I think it the other leg of 240 as I measured 95 volts ac from it to the neutral wire. One pink wire was connected to the red wire and is one half of the switch. The other pink wire was connected to the white for a common return. Since I am not using the switch at 120 I connected it to the green wire. So I think... Bijur Wire Mill Wire Use blue black 120 hot (or 240 1st leg?) white white 120 neutral pink red float switch pink green float switch red 240 2nd leg? NOTE: Ohm out your machine before wiring as I have listed. The green wire may be disconnected inside the Bijur junction box. The switch may be connected to the white wire. To use a dc voltage for the switch disconnect eh pink for the white and connect it to the green wire. Keep a wirenut on the red wire in the Bijur junction box as it may have >90 vac on it. |
| BridgePort Series I CNC BOSS 9 / R2E4 Problems | gbarker | Bridgeport and Hardinge Mills | 8 | 06-18-2010 05:51 AM |
| Lifting a B'port Series I R2E4 (BOSS-9) | lloydsp | Bridgeport and Hardinge Mills | 7 | 01-06-2009 05:53 PM |
| Series I R2E4 BOSS-9 manuals, where get? | lloydsp | Bridgeport and Hardinge Mills | 2 | 01-06-2009 05:50 PM |
| Problem- Fanuc 16i TB lubrication pump parameter | javed08 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 12-15-2008 04:54 AM |
| Boss Lubrication Lines - Replacements?? | snakebit95 | Bridgeport and Hardinge Mills | 9 | 08-01-2006 02:55 AM |
