Old 08-03-2009, 08:17 AM
Mcgyver is on a distinguished road
To convert or not, bport series 1 cnc Boss 5
I working on getting a bport series 1 cnc Boss 5 into my garage. I've seen the spindle running but not the axis, vendor says there's a fuse that keeps blowing but that otherwise it works well....the fuse problem seems fairly typical for this machine?
anyway, looking for anecdotes and comments on whether to convert or not - what the main drivers are for those who have converted.
A sister Q to this is, can the boss 5 be made to run reliably.....or is that the primary reason why people convert?
thanks
Old 08-03-2009, 11:01 AM
Moderator
machintek is on a distinguished road
Bose 5 fuse: 2 highest probability/most common: Bridge rectifier (1 for each axis) or a final drive transistor.
Note this has stepping motors with a resolution of +/- .001 inch with no provision for backlash comp. Old machines have backlash.
George
Old 08-15-2009, 12:40 AM
gschoep is on a distinguished road
I just retrofited a bridgeport 4 with steppers and it was not too hard. I am using EMC2 and Geckodrive G201s. I built a power supply with the T1 transformer in the cabinet, a cap I had on hand and a 5$ bridge rectifier. All I needed was a VFD and I was done.
I am getting 120 ipm on the X and Y and something slower for the Z. I am new to CNC but this was a pretty painless process (if I get my head working correctly).
Cost is pretty low for me since I got the G201s with the mill and EMC2 is free. I had to buy a computer mb for $30 but otherwise I had most of the hardware on hand besides a VFD as I have no three phase in my shop.
I have a bit of documentation on my blog: http://gschoep.blogspot.com
bridgeport series 1 boss 4 cnc way oil? millwrightguy Bridgeport and Hardinge Mills 1 06-26-2009 06:59 PM
Need Help!- how to convert a 3d file to a series of plane to make a CNC laser cutting? zaheer0047 Laser Engraving & Cutting Machines 5 10-12-2008 01:16 AM
Need Series I, BOSS 6.0 CNC Part split63 Bridgeport and Hardinge Mills 0 05-24-2006 05:53 PM
Boss 6 series 1 creep_pea Bridgeport and Hardinge Mills 35 11-03-2005 04:07 PM
BPort Series I and VFD questions NeoMoses General Metal Working Machines 3 09-24-2003 10:47 AM
