Old 07-24-2009, 09:11 AM
photoron2 is on a distinguished road
V2XT boss 8 doesn't like my files anymore
I loss power and have had to autoexec load the software since the batteries decided they were tired also. Since this has happened my files from surfcam do some strange things. It will start an arc and not stop, but complete the section and the rest of the circle. Should I reformat the harddrive and reinstall the software? I took the file to a friends machine and it ran fine, so I know it is originating with my machine as the problem. I am not quite sure of the answer.
One other thing I was wondering is the 30-35 psi asco switch went out at the same time and I have a 40-45 psi switch in house. Would it hurt to use this instead of the harder to find 30-35 unit? The pressure on the line is 60psi. comming in.
Ron in limbo
Old 07-24-2009, 06:58 PM
Moderator
machintek is on a distinguished road
That is a bit odd. Is your software running on DOS 5 or 6.20?
Try going to F10? and reloading the executive.
I uploaded machine software to the YAHOO V2XT group.
George
Old 07-29-2009, 03:35 PM
My setup
Hi George,
Good to hear from you again.
I have Boss 15 version 4.4 showing on the monitor using dos 6.2.
Bridgeport series 1 CNC v2xt
I tried to find a f10 load, but seems as if that does not get me to anything but probe and set up for tolerances.
I may be missing something, but it doesn't show up on my drop menus.
I went to yahoo groups but where is the software download area?
Thanks as always.
Ron
Old 07-29-2009, 07:51 PM
Moderator
http://groups.yahoo.com/group/v2xt/files/
George
Need Help!- Not working anymore nenetwork Mach Software (ArtSoft software) 1 04-17-2009 01:06 PM
V2XT files OS & schematic pdf 9 1/2 Bridgeport and Hardinge Mills 0 11-13-2007 05:48 PM
Program load/select list on V2XT Boss XT 3.4 control rfdoyle Bridgeport and Hardinge Mills 0 02-23-2007 08:36 AM
New to Bridgport V2xt Boss 9 jam1960 Bridgeport and Hardinge Mills 5 08-23-2006 09:48 PM
Z-axis won't jog anymore Liv2fish2 Machine Problems, Solutions , Wireless DNC, serial port 5 01-13-2006 06:20 PM
