Originally Posted by lerman 1 - Do I really need 1350 Oz. In. motors? I was looking at the Reliance 0690 servos that are rated at 22 Lb. In. (352 Oz In) continuous. Elrod gears them up 2:1 and I would do the same. There seems to be a factor of 3 or more in cost. |
I am using 916 oz/in steppers on X and Y and 260 oz/in on the Z. I have 2:1 gearing on X and Y and 3:1 on the Z and have not had any problems at all so far. I am almost ready to swap the motors over onto my series 1 CNC Bridgeport but I will be using a 916 for the Z on that.
2 -- Who besides Elrod has a Z axis quill conversion? Are they any good? What provisions are made on these conversions for limit and home switches? |
Sorry not much help here as I made my own brackets up.
3 -- The acme screws on my machine are 1.250-5tpi. The largest of Rockford's screws in 5 pitch seems to be 1.150 in diameter. Is that likely to be a problem? |
It wont be a problem as when you look at a ballscrew the ball track is not nearly so deep as the acme thread so the root of the ballscrew will still be thicker than the acme. I have 20mm on mine and again no problems.
4 -- Who besides Elrod has motor mounts/pulley kits for the X and Y axis? |
As above, made my own so cant help.
5 -- My intention is to use EMC for the software (I'm a linux guru), and pico controllers. Does anyone have any comments on these choices? |
No experience with that or any other controllers so will just tell you what I think of the one I use. I use Mach3 and it works really well, there is a great community on the Yahoo group and also on the suport forum. Art (Mr Mach) is a genius who is always adding functions and helping out. The Yahoo group and the forum also has a huge number of very knowledgable people and they work in conjunction with Art to make things happen. I have been using Mach for about a year now and the progress it has made in that time is unbelievable and I would say it must be one of the best CNC controllers around for the hobbiest and I think even some of the big players are starting to take an interest in it.
Hood
