Old 07-12-2009, 02:26 PM
Trump is on a distinguished road
The Gecko 320 servo drive
Will the Gecko 320 servo drive run the servos on a BP mill with the MT30r4-58
servo motor or should I stay with the Bosch drives that came with the mill
I am trying to upgrade the TNC 145 controler and go with a PC based Machine not sure what to do?
Old 07-16-2009, 10:24 AM
Doug Schwochert is on a distinguished road
conversion
Hi I did a Bridgeport with the origional servo motors and the 320s
80 volt power supply works great. search some of the older Bridgort threads for some of my prior posts for more info.
Doug
Old 07-16-2009, 06:32 PM
What break-out board did you use? I have a ton of questions to ask you I am
not sure on what works with what and how to you know. I have about 1300.00 I can spend on getting this mill up and running. I just need to becareful
on how I go. I have talked to John at Pico systems. I like him and the prices
are good. Have you had any dealing with him?
Gecko Drive Don Kellogg DIY-CNC Router Table Machines 8 08-10-2008 12:12 PM
320 gecko drive Ed Williams Gecko Drives 4 05-19-2008 12:20 AM
Possible Gecko Drive? juzwuz Gecko Drives 7 03-19-2008 11:00 AM
Driving 160v servo from gecko drive ahmedrehan Gecko Drives 1 10-06-2007 09:05 PM
Which Gecko Drive Lloyd Gecko Drives 5 05-31-2006 01:35 AM
