Old 07-11-2009, 04:41 PM
nippy7 is on a distinguished road
Interact Problem after Transportation
Hi, i have recently bought a Bridgeport interact 2500 with a heidenhaim control unit.
I saw the machine working when i bought it, but after transporting it to my unit, the machine powers on, however when i try to power the motors to home the 3 axis there is no response.
Could there be anything that i have overlooked or need to check after transportation? As my knowledge is only with a relatively simple EZtrack.
Any information would be much appreciated.
Many Thanks
Tony
Old 07-11-2009, 05:59 PM
gus gus is offline
gus is on a distinguished road
Be very specific
does the power enable work?
it may just be on a limit
Old 07-11-2009, 08:18 PM
oldtigger is on a distinguished road
Hey Nippy, Does it have a battery backup? Could be you've lost all your paremeters, and will have to reenter them after you've replaced with New batterys.
Old 07-12-2009, 12:33 PM
Originally Posted by gus View Post
Be very specific
thanks for the reply. When i turn the main power on the montor/control panel boots up but when i try to enable power to the motors nothing happens. just a small click from the rear panel and while the button is pressed this message comes up at the top:
"Pass over reference point"
I believe it has got battery backup, would i be able to tell if the battery was the cause?
Many Thanks
Old 07-12-2009, 09:02 PM
gus gus is offline
You have not lost your parameters
If you had it would probably be in German
If any of the axis are near the end of travel, move them off
It could be anything in the EMO string, including lube level
Old 07-16-2009, 04:36 PM
robinhood2b is on a distinguished road
it may be obvious but you have checked that the feed rate override knob has not been turned right down as i have fallen in to this trap on my interact 1 mk 2 with TNC2500 FITTED. make sure the knob is turned up ie clockwise.
mark
Old 07-25-2009, 09:14 AM
Moderator
machintek is on a distinguished road
What is your status? Running?
George
Strange problem ! BP II interact 4 bherr Bridgeport and Hardinge Mills 11 08-28-2008 09:48 AM
Machinery Transportation SpecialtyTrans Product Announcements & Manufacturer News 0 02-29-2008 07:26 AM
Transportation available from WA to CA Radius General Metalwork Discussion 0 09-04-2007 11:56 PM
Interact 1 mk2 problem yarpo Bridgeport and Hardinge Mills 3 08-07-2007 01:12 PM
Bridgeport Interact 24v DC reg problem Paul_Leoni Bridgeport and Hardinge Mills 3 11-14-2006 03:15 AM
