| I have purchased a used VMC 1000, and after a hard drive crash, and an ER Module repair, The machine ran for an hour or so, as I was checking everything out. I shut the machine down, and came back in a few days later, the machine homes out, but now the spindle oscillates, and I cannot find the problem. Also, I do run on a 30 hp, rotary CNC converter, could this be a problem? any suggestions? Thank you, Kiser Last edited by Kiser; 07-03-2009 at 09:43 PM. |
| I don't think that I can help you out much. The only thing I can tell you is that I have a Hardinge VMC 600 and it runs fine on my phase converter. The only thing you might check is to make sure you haven't lost the parameters and that the D cell batteries have been replaced. They should be right inside the panel. Read the manual. You can also contact Hardinge (607) 734-2281 they are very helpful, even if you purchased the machine from another party. Make sure you have the serial number, it is located on the electrical panel door. If it has a Fanuc OM-D control you may want to check with some of the guys on the Fanuc forum. There are a couple of real sharp guys there that could probably help you out. Pete |
| hardinge vmc1000 | samu | Bridgeport and Hardinge Mills | 3 | 05-11-2008 06:44 PM |
| VMC1000 Drive Engagment Issue | Millman1000 | Bridgeport and Hardinge Mills | 3 | 03-28-2008 07:48 AM |
| Need Help!- vmc1000 heidenhain510 | FLOATER1234 | Bridgeport and Hardinge Mills | 5 | 03-14-2008 06:51 AM |
| Problem- VMC1000/22 Mould Master TNC426 | mcwmah | Bridgeport and Hardinge Mills | 1 | 01-30-2008 06:20 AM |
| electrical prints VMC1000/22 | AlexCNC | Bridgeport and Hardinge Mills | 9 | 10-07-2005 11:20 AM |
