Old 07-03-2009, 08:19 AM
creep_pea is on a distinguished road
Boss Air Brake
Hi
I've just put the air brake back on my Boss, it works well when you turn the spindle on and off quickly but when you leave the spindle running for a long time it will coast to a stop before the brake even comes on.
I take it this isn't normal.
I think it may have something to do with the spindle contacts as these are sticky, I've had problems with starting the spindle when the machine gets warm so it could posisbly be that.
Any ideas about cleaning the contacts? in situ preferably.
Old 07-03-2009, 12:23 PM
gus gus is offline
gus is on a distinguished road
wonder if it is dragging
Old 07-03-2009, 06:13 PM
Moderator
machintek is on a distinguished road
Wonder if the air cylinder is gummed up?
George
Old 07-16-2009, 05:53 PM
The air cylinder is brand new, it works fine.
Been looking at it again, I'm now fairly certain it is the spindle contacts as you can here them clicking in and out so when its been running for a while and you switch it off the motor turns off then a while later I hear a relay click the brake comes on.
Chris
New Machine Build- 600mm Box bend brake (Finger Brake, pan Brake) RotarySMP Bending, Forging,Extrusion... 20 09-06-2010 10:56 AM
easy boss w/ fair wage or diffcult boss w/ high pay? Chipload Polls 17 06-11-2008 07:19 AM
Need Help!- HAAS TL 1 Brake rtuls35 Haas Lathes 12 03-07-2008 09:38 AM
Boss 9 Boss 10 parts swop Drewboy Bridgeport and Hardinge Mills 1 03-29-2006 10:16 PM
