Old 07-01-2009, 10:52 AM
dmac88 is on a distinguished road
EZ TRAK OFF IN Z AXIS
Hello,
Our Ez-Track mill is out in the z axis as much as .030" when the quill is fully extended ( approx. 4.5"). Basically, what we measure with an indicator does not correspond to the displayed value. We have just replaced the encoder on the z axis motor but this has not solved the problem. Could it be the backlash or leadcomp settings? Perhaps it is the slide which measures the z axis travel? All suggestions will be greatly appreciated.
Old 07-01-2009, 12:00 PM
TonyAllen is on a distinguished road
Our Z-axis got out about .030 also it turned out to be the Screws holding the pickup was just loose enough to give when the cable got taught ...
Tony
Old 07-01-2009, 06:01 PM
Moderator
machintek is on a distinguished road
So the error is progressive as the Z moves and returns to 0?
Have you checked the lead error/pitch error comp?
At the main screen press *, a window will pop up asking for a code. The code is 11235 followed by ENTER twice.
George
Old 07-08-2009, 12:22 PM
Thanks for the advice. We have tried to change the leadcomp but it does not seem to have any effect on the z axis. Could it be perhaps a defective z axis scale.
2 axis EZ Trak post? zcases Post Processor Files 3 12-18-2008 04:42 PM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
4th Axis for EZ Trak Grayling Bridgeport and Hardinge Mills 2 09-01-2008 01:05 PM
EZ-Trak Z Axis Trouble ivangene Bridgeport and Hardinge Mills 2 01-24-2008 12:40 PM
EZ-Trak losing Y axis Zero melamark Bridgeport and Hardinge Mills 4 08-30-2006 10:52 AM
