Old 06-28-2009, 09:55 AM
BetaBob is on a distinguished road
Bridgeport 1000/22 TNC370 Lube Cycle Parameters
We bought 2 BP VMC 1000/22 w/ TNC 370 controllers earlier this year. 1 has a lube cycle time of 10 seconds every 30 minutes and the other has a cycle of 20 seconds every 5 minutes.
Can anybody provide me with the Machine Parameters that adjust these times? I've downloaded all of the documentation I can find on the TNC 370 but none of them list these parameters.
Thank You
Old 06-30-2009, 10:07 AM
gus gus is offline
gus is on a distinguished road
They are in the service manual which I downloaded from the heidenhain website
Computer is glitching right now so cannot post them, but all I can see is that 4060 deals with travel dependent lube
It may be in the plc not the parameters
Old 06-30-2009, 02:52 PM
Thanks Gus.
I have downloaded the manual for the TNC 370 and the 4060 parameters have something to do with "automatic lubrication". However the parameters are all "0"s on both machines and they have different cycles. I never thought about the times being hard coded into the PLC. I had read in another thread that the times were set by a MP but they didn't specify which one(s). I sent a message to the memebers on the thread but have not heard anything back.
Old 06-30-2009, 05:56 PM
gus gus is offline
call rick at heidenhain service in Schaumberg
if it is plc he won't be able to help, but you can read and edit the plc but it can be daunting
Old 06-30-2009, 10:21 PM
Moderator
machintek is on a distinguished road
From my service tech in Tenn:
Try this….
4110.5 time between lube cycles
4110.6 time out limit for lube to reach pressure
4110.7 lube on time
George
Old 07-07-2009, 12:07 AM
Thanks George:
That corrected my problems. Now all I need to do is get everything backed up.
Problem- Bridgeport stopping in cycle pinkminky Bridgeport and Hardinge Mills 3 09-30-2008 07:07 AM
Need Help!- Mitsubishi M-V70C can cycle parameters daddyjason2004 Mazak, Mitsubishi, Mazatrol 0 09-24-2008 12:30 PM
Problems connecting laptop to TNC370 iknownothing Bridgeport and Hardinge Mills 2 01-24-2008 06:26 AM
vaseline ok to lube the ways on a bridgeport? mbwittig Bridgeport and Hardinge Mills 32 11-18-2006 12:34 AM
Bridgeport Lube System kewl_cat Bridgeport and Hardinge Mills 5 03-05-2006 10:54 AM
