Old 06-04-2009, 04:32 PM
barbque is on a distinguished road
Recommendations for R8 spindle taper regrinding
I would like to get my R8 spindle taper reground. Does anyone have some contacts they would like to share?
Thanks - Kris
Old 06-04-2009, 05:02 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Any ID grinding shop can do it. It's the simplist taper to grind, you just have to find the specs for the angle to give the machinst, tell him to "just dust it".
Other than that, you can contact a repair shop, off the top of my head,
http://www.centerline-inc.com/servic...pair/index.php
http://www.setcousa.com/index.cfm?fu...FQOIFQodchGvJQ
http://www.pba-spindles.com/
MC
Old 06-11-2009, 05:45 PM
titchener is on a distinguished road
The Wells-Index mill company will regrind any knee mill spindle, and also offers bearing replacement. They typically run adds on Ebay selling the regrinding service.
If you have this done locally, you want it done with the spindle mounted in the quill so any bearing misalignment is taken care of, don't have it done just using the bare spindle. Like I did back before you could get good info like this off the internet. Mine still came out pretty good though.
Paul T.
Spindle Recommendations MayanArch Wood Working Tooling 3 01-01-2009 09:03 PM
Has anyone got the 30-taper spindle? digits Tormach PCNC 66 07-23-2008 09:17 PM
5 Hp Spindle Recommendations skypoke DIY-CNC Router Table Machines 2 06-30-2008 07:53 PM
Spindle recommendations seansear DIY-CNC Router Table Machines 3 09-01-2006 11:27 PM
Regrinding spindle taper hole Ch_Irawan Mechanical Calculations/Engineering Design 27 03-12-2006 02:43 PM
