Old 05-30-2009, 02:56 PM
andrewbishop66 is on a distinguished road
spindle to pully play jhead
I have a Clausing Kondia its a bridgeport clone J type head
there is play between the drive pully and the spindle (rotary play) it rattles with or without load its well oiled and greased any ideas
Thanks Andrew
Old 05-30-2009, 03:17 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Bushings, if it is exactly like a BP. They are just plastic, normal replacement parts.
MC
Old 05-30-2009, 07:11 PM
HimyKabibble is on a distinguished road
With the backgear in "High", and the dog clutch engaged, hold the front pulley with one hand, while turning the spindle back and forth with the other. If you get the "clunk", then it's probably wear in the splines between the spindle and the front gear of the backgear. If you're lucky, the wear will all be on the backgear side (female) spline, which is part of the backgear hub, and not stupid expensive or difficult to replace. If the spindle spline is worn, that's a whole 'nother ball of wax.... You can quiet it down, at least temporarily, by greasing the hell out of the splines with some thick grease.
Also make sure there's no slop in the dog clutch.
Regards,
Ray L.
Old 05-31-2009, 12:21 PM
I think the wear is between the splines and back gear its consistent regardless of extension so it is most likely to be in the front back gear the only problem is going to be finding a supplier in the UK
thanks for the help
Andrew
Old 06-01-2009, 06:56 AM
colin1544 is on a distinguished road
Spindle rattles
Hello Andrew Is your machine a 2 or 3 axis if 2 axis consider a second hand belt change head and put a VFD drive on it for the speed variation, or if 3 axis is it a Elrod type adation on the spindle feed if so try Terry Braithwaite at Bridlington on 01262 606691 he is the man who rebuilds Bridgeports and may mave something to help you Cheers Colin.
Bridgeport/Jhead retrofit. Sweeney Bridgeport and Hardinge Mills 12 01-31-2009 09:56 AM
series one varible speed pully warp alex 850 Bridgeport and Hardinge Mills 0 02-28-2008 07:46 PM
belt and pully question please help . mjs79 Linear and Rotary Motion 9 10-24-2007 03:13 PM
bridgeport series 1 jhead clone purchased! fignoggle Bridgeport and Hardinge Mills 3 02-17-2007 12:30 AM
pully gears and belts for servos replicapro Benchtop Machines 3 07-22-2004 04:23 PM
