I have just purchased an Bridgeport series one with a 3 axis HEIDENHAIN #135 CONTROL. Is this control of any use or should I just replace it with MACH3 or something else? Are the motors and the drives usable with MACH3 or should I replace them also? At this point I think will be using Dolphin cad/cam or Vector cad/cam as the drawing/cam program. What are your opinions or idea's....... Jim |
| I personally use dolphin partmaster pro and mach 3 myself. Couldnt be happier. Looked at vector years ago and uninstalled it about as quickly as I installed it. Not sure what they are up to now. The motors and drivers should be usable with mach 3. |
| Harley4ever, So If I remove the Heidenhain controller You think that MACH3 will be able to directly interface to the Heidenhain drives. Then I can reuse the controll panel and switches to interface into MACH3 keeping the overall look but with better functionality. Thats cool. Jim |
| TNC 135 is point to point no arc's I don't think it has cutter comp. TNC 145 is 2 and 1/2 axis with cutter comp. TNC 150 and up to 155 (as I recall) is full 3 axis with cutter comp in any two axis. I think you may be able to upgrade it to the 145 and maybe the 150 thru 155. I would check with a dealer who knows or contact the Heidinhine factory. I, in the past, upgraded a 145 to a 155 and only had to change the PLC ( 1987) I did have to come up with about 250 parameters and it took about three full days to do it. If you can find a 145 or 155 and the servo and drivers are the same, I do it... I would only consider retrofite if you can find these controls cheap. Also I am guessing you have no Z axis so a retro for 3 axis could be costly. Your options are to leave it alone and learn the system then consider whether to upgrade. Or... learn it, to understand programming & after you clean it up, sell it for something newer, or if money not of concern use it for simple second ops. Is this a hobby machine, a money making machine or a little of both? Steve Last edited by scadvice; 05-29-2009 at 11:36 PM. |
| Steve, It is a 3 axis machine. Z being the spindle. It won't be used for production more for prototyping on a few projects I want to work on. Own and run a small AV company. My machine background is about 7 years of mill and lathe work about 20+ years ago. Pretty good computer and electronics engineer now. Can design and make boards Porgram pics etc. Jim ![]() ![]() Last edited by jbcj; 05-31-2009 at 11:56 PM. Reason: pictures |
| I use the bridgeport steppers with modern 8 amp drives and mach 3 with no problems the mill i have is a bridgeport clone retro fitted with s/h bridgeport steppers works ok for me most of my stuff is one off custom items Ithink it would struggle with production work Andrew |
| Yes it`s a three axis machine with a point to point positioning control.You can download the Heidenhain manuals for it from here. https://filebase.heidenhain.de/doku/...72/N13772.html |
#10
| Gridley51, Thanks for the link. After looking at some of the documents do you know if there is a drive for each motor or 1 for all three? Do you know if my system has the 20um,40um, or the 100um glass scales. Jim |
#12
| jbcj, I would expect the machine to have only one axis drive to control the three motors.That means you can machine in a straight line only and parallel to the machines axis.No 45 degree moves. I have no idea what resolution of scales would have been used. Mark. |
| Bridgeport Interact 412/Heidenhain TNC 151 HELP? | larrynsr | Bridgeport and Hardinge Mills | 16 | 03-17-2012 02:21 PM |
| Need Help!- Bridgeport interact 412 W/ Heidenhain 2500 control | RMARCH | Bridgeport and Hardinge Mills | 26 | 09-27-2008 07:06 AM |
| Replaced encoder, replaced cable, still can't get 4th axis working | ralph@nes | Haas Mills | 40 | 02-07-2008 05:03 PM |
| Looking for help for bridgeport/heidenhain 155 | plane magic | Bridgeport and Hardinge Mills | 6 | 02-26-2007 07:00 PM |
| Basic questions about Bridgeport VMC1000 with Heidenhain control | Roe Racing | Bridgeport and Hardinge Mills | 9 | 03-02-2006 04:54 PM |
