Old 05-24-2009, 10:11 AM
Tommy is on a distinguished road
Series 1 R2E4
Sometimes the Machines will Home and then Axis trips out when starting to move to 0,0 point.
Sometimes axis trips out while trying to Home.
Fault FFEC X-Tack Disagrees with Comman.
Z Tack Disagrees with Comman
Any Idea's
Old 05-24-2009, 12:04 PM
Moderator
machintek is on a distinguished road
Does the machine appear to move faster or slower than usual? Did it ever work correctly? Is it on a phase converter? I was working on a machine one day during a brown out and could hear the machine start fast and slow down because the energy was not there (low incoming voltage).
i focus on this because It seems a bit odd that two axis would do this so it must have a common source. I would also look at the IFC/DPS assembly. It has test points on it.
These are DC servo motors with tachs and brushes in them. They do wear out.
George
Series II R2E4 Programming AppEng Bridgeport and Hardinge Mills 3 09-26-2008 07:01 PM
Bought a Series 2 R2E4 CNC...have ??????'s AppEng Bridgeport and Hardinge Mills 0 09-25-2008 05:47 PM
Bridgeport Series 1 CNC R2E4 (??) l u k e General Metalwork Discussion 8 01-24-2006 07:39 PM
R2E4 Series II Way Wipers? arsenix Bridgeport and Hardinge Mills 2 07-06-2005 01:40 PM
R2E4 Series 1 utengineer04 Bridgeport and Hardinge Mills 1 06-30-2005 06:20 PM
