I pulled the x way covers off my 1993 VMC760 over the weekend because i was getting some noise in the X axis. The thrust bearing on the left side is bad.....I can feel it thunk when i turn the screw. My manual does not cover how to replace it. I almost feel out of my chair when i got a quote on a bearing. $769.00 each!!!!!!!! Must be made of gold.
I need to know to know how to change the bearing. I assume there is a way you preload it with the spanner nuts?
Please help!
Replacement is not that difficult. Make sure the bearing are out in correctly including the orientation to each other. Most have a V scribbled across the outside races.
Usually we hand tighten them, pit a dial indicator against the end of the ball screw and stretch the ball screw about .003 inches using the spanner bearing nut. It takes a lot less force than one would think to do so.
George
