Old 05-08-2009, 10:41 PM
tsquint1138 is on a distinguished road
X Axis Stalling?? (no movement.)
I'm retrofitting a BOSS 4 with the original drives & steppers. All axis (XYZ) were working yesterday. Fuse 6 blew (I think it was 6. It's the 1.4A on the Limit overide circuit.) Replaced it today, now no X Axis
I can jog Y & Z but not getting any movement on X. I can hear the X axis stepper hum when it gets the signals from mach3, and the mechanical counter twitches.
Here's what I've Tried in troubleshooting problem.
Checked current across fuse12 & set ACC P1 to 8.2amps static.
Swaped SMD board with Y. Y works with X axis SMD board, X does not move with Y board.
Swaped pins 1&2 with 3&4 on K8 connector. Y Axis moves when 3&4 are connected to pins 1&2.
Checked continuity from K8 pins 1&2 with the card edge connector on X axis SMD socket.
SMD Board swap should have ruled out bad SMD Boards. K8 Pin swap should have ruled out bad BOB.
Any help would be much appreciated.
Old 05-09-2009, 02:09 AM
Superman's Avatar
Superman is on a distinguished road
I'm going to throw a wobbily at you.
Are you sure it is electrical ?
Can you move the axis leadscrew by hand with power OFF ?
Might be a bearing or a motor lockup ( mechanical fault )
Old 05-09-2009, 08:31 AM
Moderator
machintek is on a distinguished road
Check final drive transistors for a short.
2N6547.
George
Old 05-09-2009, 12:03 PM
You mean Q1-Q4 on the SMD? (Those have been replaced in the past and are no longer that number -Have not looked them up to see if equiv.), Don't see 2n6547's anywhere.
I swaped X & Y motor wires at terminal block. Y drive runs X Motor, X drive fails on Y motor. Can swap SMD boards with no change.
Old 05-09-2009, 07:49 PM
Checked the final drive transistors (On the big heatsink in mounts for each axis behind the ACC & SMD boards Right?) No shorts, Swaped the X & Y Transistors, (moved each assemby & re-wired) No change. X still fails.
Old 06-04-2009, 09:06 AM
Fixed it!!
The diode across motor winding X2 to power resistor 87 failed to a short.
Replaced it with the biggest rectifier I could find in my parts bin to test, and axis works fine.
Now to order the proper part.
Need Help!- New SX3 - Axis Movement meyermicro Syil Products 11 05-27-2008 08:36 AM
Axis Movement KARD CamSoft Products 1 05-21-2008 05:29 AM
Y axis stalling/hanging up tdnp DIY-CNC Router Table Machines 7 12-15-2007 02:13 PM
Axis Movement UKRobotics General Metal Working Machines 2 12-17-2004 01:33 PM
4th axis movement (and a few other gen ?s) corpse General Metal Working Machines 2 08-04-2004 06:13 PM
