Old 05-01-2009, 11:42 AM
theguild is on a distinguished road
R2E4 will not home
After I enable axis drives I'm suppose to hit enter and then execute to begin homing.The axis drives do turn on but the machine will not start to home.Under help key it tells me "ADE went to jog due to zap" and "jog before homing".My Manuel shows me this under success events but does not tell me how to fix it.Any help would be appreciated
Keith
Old 05-01-2009, 07:28 PM
Moderator
machintek is on a distinguished road
Axis Drive Enable went to a Emergency Stop condition due to a machine fault (ZAP).
Maybe a axis is sitting on a axis limit switch. Most common is the Z axis.
Try using JOG OFF LIMITS.
Z axis first. But usually if the Z axis goes too far, things get bent up inside where the switch is and possibly the Z axis is jammed.
You may need to remove the fiberglass surround, and swing away the CRT, remove the sheet metal access plate and check the Z axis switch and mechanism.
If the Z is jammed, you will have to un-jam it.
George
Old 05-04-2009, 10:20 AM
R2E4 homing
Hi George
First Id like to say THANK YOU for all the times you helped me over the past few years on this machine.
The Z Axis is not jammed.I can move all 3 axis manually
When I hit the axis drive the drives turn on but my screen goes to setup jog not to the screen that says "important "and then I hit enter, that screen goes away then I hit execute to home.
Im also blowing fuse 5 in the back panel
any ideas?
THANKS
KEITH
Old 05-04-2009, 09:40 PM
Moderator
Keith, per the maintenance manual Fuse 5 protects 2 fans. I would make sure they are not bad.
Going to jog, means it thinks it is on a extreme limit switch. You may need to check them for a broken wire. In other words at the end of this switch string you need to see voltage.
George
R2E4 Tapping? arsenix Bridgeport and Hardinge Mills 2 02-19-2011 01:03 AM
Problem- bridegport R2E4 needs to re-home theguild Bridgeport and Hardinge Mills 6 09-20-2008 05:10 AM
R2e4 steve ohalloran Bridgeport and Hardinge Mills 2 02-18-2007 01:02 AM
r2e4 drives najnielkp Bridgeport and Hardinge Mills 0 10-23-2006 08:45 AM
R2E4 Help jeep534 Bridgeport and Hardinge Mills 2 10-14-2006 11:45 AM
