Old 05-01-2009, 08:14 AM
Allen123's Avatar
Allen123 is on a distinguished road
Question Model # 2R2EA S# 186 Bridgeport R2E4 Boss 9.2 Programming
I need to know if I can use normal RS - 232 communications with this machine. Predator Editor
And the format of the G-code so I can write a post for it.
I know the machine is from the 80's
I hope it doesn't have the EZ Troll communication protocols.
Anyone that would know about this machine please write back or give me a call.
727-744-2276
Regards,
Allen
Old 05-01-2009, 08:52 AM
Moderator
machintek is on a distinguished road
I had a R2E4. First of all I recommend getting a programming manual. Try machinemanuals.net or Ebay.
At first I used a Radio Shack TRS80 model 100 to upload download and edit with RS232.
Later I used a MAC running EZCAM (EZMILL) to generate programs and download.
I have also used PROCOMM for upload and download as well as editing in terminal mode (chat). It was a DOS shareware version. Similar to KERMIT.
Powerful editor and canned cycles.
Port A is used for upload, download and editing. Port B for EZLINK uploads/downloads and DNC.
Control can store more than one program but memory is limited. Most CAM systems have many extra lines of code. Typically I could consolidate a 8 page program to less than one using loops and macros.
George
BridgePort Series I CNC BOSS 9 / R2E4 Problems gbarker Bridgeport and Hardinge Mills 8 06-18-2010 05:51 AM
Need Help!- Communications Problem: PC--> Bridgeport Model R2E3 (BOSS 8) rams_head Bridgeport and Hardinge Mills 0 03-04-2009 08:15 PM
Archie's first cnc machine Bridgeport R2E4 Boss 9 to Mach 3 jeep534 Vertical Mill, Lathe Project Log 8 09-10-2008 12:47 PM
Bridgeport Series II CNC w/ BOSS - Programming rocknrolljunky Bridgeport and Hardinge Mills 35 09-11-2007 01:56 PM
Bridgeport CNC Mill, Model R2E4, Boss 9 Control Tbucit Bridgeport and Hardinge Mills 5 03-17-2006 09:39 PM
