Old 04-28-2009, 07:02 PM
Zeke13 is on a distinguished road
EZ Trak Internal addressing error
One of our programmers is getting an internal addressing error that stops the program.
This seems like it could be a corrupt memory issue. Anyone have any ideas?
Zeke
Old 05-01-2009, 11:15 PM
Tigrita is on a distinguished road
Internal address error
is the internal address error a #4 , I am having a similar problem it might have to do with a post processer requriement for useing G code .txt programs files . I am haveing a problem running a .txt file that was created in master cam
Old 05-02-2009, 01:47 PM
Zeke
I don't remember what the error # was the 1st time, but the next time it was #10. We are using the post processor for SmartCAM that we've been using for 10+ years. If this has happened before I am unaware of it.
Old 05-02-2009, 07:56 PM
I am trying to use a editor called preditor , for a program that was created on master cam. It seems that the mill is not recognizing the text file for some reason I inceryed the numbers for each line obtion , I also used the ACSII sysmbol before the % and it gets the same error #4. I am not that familure with useing CNC's in the G code mode I always just used the easy track program system that it comes with
Old 05-19-2009, 05:42 PM
Wallo's is on a distinguished road
Tigrita.. suena medio latino tu Nick..
Can you send me email ...??
eduardo.mata@gulfstream.com
I work with Smartcam, Mastercam9, MastercamX2 for Bridgeport.
Old 05-19-2009, 06:55 PM
Gncc50 is on a distinguished road
x
EZ-Trak start-up error jfm Bridgeport and Hardinge Mills 13 10-08-2009 09:53 AM
Need Help!- EZ Trak Error dustindavenport Bridgeport and Hardinge Mills 2 12-25-2008 07:15 AM
ez-trak system error Tru Cut Machine Bridgeport and Hardinge Mills 2 08-27-2006 09:33 PM
Internal Addressing Error BobL Bridgeport and Hardinge Mills 11 06-06-2005 05:11 PM
Internal addressing error BobL General CNC (Mill and Lathe) Control Software (NC) 1 05-26-2005 11:55 AM
