Old 04-23-2009, 03:03 PM
Bwana Don's Avatar
Bwana Don is on a distinguished road
VMC-760 Need drawbar & tool carasoul
Does anyone know where I can get a drawbar for a 1993 VMC-760 Bridgeport Vertical Machining Center? Also need the tool carasoul.
We bought this machine new in 1993 and have run the hell out of it since. It made us a lot of money but now is in jepordy of becoming scrap. The tool carasoul (changer that holds the tools) is broken and Hardinge want $9,000 for a new one! We still have 7 tool pots to use so we can limp along this way.
To make matters worse we crashed the machine hard. Broke the tool stud and bent the drawbar. Also tore up the taper inside of the spindle. This is quoted at $5000. The drawbar is $1500 of this.
I would like to repair the machine on the cheap. It could be used for R & D projects in a year or two when we buy a new machine. Otherwise I need to buy a used machine now. No money at the moment for new.
Any suggestions for finding parts? Thanks in advance for any responses.
Still working in the "D".
Old 04-23-2009, 05:57 PM
gus gus is offline
gus is on a distinguished road
I have many spare BT tool pockets for the 22 tool carousel, if that is what it uses.
You may want to look at another machine, as they are not that expensive these days
Old 04-24-2009, 06:58 AM
Bwana Don's Avatar
We are looking at used machines and there are some real bargains out there. I think this machine is going down. If we don't get a solution in a week or so then we'll need to do something. We have 3 machines running 2 shifts. When one goes down there goes a third of your capacity.
Old 05-01-2009, 08:53 AM
Bwana Don's Avatar
We are getting a drawbar machined up. The spindle taper is getting reground as well. Total cost is $4700 total. This machine should be back up and running in 2-3 weeks.
Gus, we need the whole tool carrige. The one that rotates and holds the tools. It is a 16 tool carousel. I hope I'm describing this well enough. It's an aluminum casting about 20" in diameter, has pockets in it for holding the tools. Keys bolt into it for orientation of the toolholders.
I can post a picture if anyone thinks they have one for me.
Old 05-01-2009, 05:47 PM
gus gus is offline
re
Ah, must be different from the 22 tool[that I have] In the 22 the pockets pop together to form the carousel. then 4 or 5 long bolts hold it up to the pivot assembly
Old 05-03-2009, 02:38 PM
gus gus is offline
there is a similar machine on ebay for like 9k, in MO I think
VF2 Drawbar rrbmachining Haas Mills 18 01-04-2009 03:00 PM
TC-22 DRAWBAR tpmx57 Bridgeport and Hardinge Mills 10 12-18-2008 08:29 PM
drawbar advt001 Cincinnati CNC 2 11-23-2008 05:49 PM
Problem- VF4 - DRAWBAR ErikVF4 Haas Mills 2 06-11-2008 01:34 PM
Where to buy a drawbar? MrWild Bridgeport and Hardinge Mills 3 07-31-2006 06:44 PM
