Old 04-19-2009, 04:25 AM
Bigbloke is on a distinguished road
Anilam 1100 Tool change
Hi
I'm just trying to get my first program to work on an Anilam 1100 equipped Bridgeport Clone mill.
I am trying to single step through the programme to see what happens, no tool, spindle off, table cranked down well out of the way, I just want to check that the table and spindle do what's expected.
When I get to a line calling for a tool change, it will not move on from that stage. I'm not sure whether I need to press something specific to continue at a tool change or whether the post has not correctly formatted the command. Certainly just pressing the green go button isnt getting me past this line.
The offending line is...
6 Tool #2 Mcode 8
The manual I have isnt complete so it may be that I am missing something truly basic here (hopefully)
If anybody can advise, that would be a real help.
Paul
Old 04-24-2009, 12:02 PM
Ok
Figured it out. For some reason it doesnt like the coolant on command ie:
Mcode 8
As soon as I re post to take that out, everything goes fine. I dont understand why it doesnt like it but I'm okay with turning the coolant on manually for now.
Paul
Old 04-24-2009, 12:23 PM
stevo1 is on a distinguished road
What exactly does your code look like when turning on your coolant via M8? What else is in the line with the M8? Can you not just put the M8 in a seperate line by itself?
Stevo
Old 04-25-2009, 12:46 AM
Hi Stevo
The line looks like this....
6 Tool #2 Mcode 8
I havent tried putting it on a seperate line yet as I will be using an external coolant pump and havent wired it in yet.
Paul
Anilam 1100 postprocessor zrrigid Surfcam 3 04-09-2012 09:09 AM
Anilam 1100 english bob General CNC (Mill and Lathe) Control Software (NC) 2 02-08-2008 09:12 PM
1100 and 1400 anilam cpu need new where to get jetski Milltronics 0 11-27-2007 11:22 AM
Looking for a UG NX4 post for an Anilam 1100 control Tom McMahon Post Processor Files 1 11-04-2006 04:07 PM
anilam 1100 tmt_92021 General Metalwork Discussion 1 07-09-2006 11:28 AM
