Is this as would be expected? This was my first over-haul... new belts, bearings, grease.... Operation up to 1800 RPM is purdy darn quiet. Starting at 2000 RPM the top end begins to generate a bit of noise, on up to 4000 RPM it's very loud (louder than prior-to the overhaul). While I had belt-squeel and bad-bearing rattles before, the sound is of rotation (low-pitch whirling). There is almost no vibration, so I suspect the sound to be from the veri-belt and pulleys. Last edited by Hythos; 04-18-2009 at 12:08 PM. |
| The most common issue with A vari drive (2J)head are the bushings in the vari-drive discs wearing out. Did you change those? George
| The bushings (plastic) were in great shape with a snug fit and still moved when pushed. I've heard of people lubing with lithium, but didn't wanna take a chance of the grease getting on the pullies. I lightly polished the motor shaft and veri-speed spindle pully hub to remove any burnish or discoloration with steelwool then wiped down with alcohol. I had the bushing kits but didn't feel any appreciable wear, so skipped that for now. Thanks George =) Additionally, after ramping through about 10 cycles from slowest to fastest, it's quieted down some, and seems to be about normal now at 4,000rpm (though, still a bit louder than anticipated.) Since I won't be running a 1/16" endmill often, I don't have a real reason to max out the RPM's, so it should be fine at 2k. |
| How Loud is your furnace | sambuddy | Casting Metals | 8 | 12-17-2007 01:24 PM |
| Is this too loud? | asm | Benchtop Machines | 6 | 08-12-2007 01:38 PM |
| beep too loud | 1ctoolfool | Haas Mills | 4 | 03-26-2007 11:40 AM |
| FREE Lathemaster Mill with IH cnc kit - You Haul | CNCPlastic | Industrial Hobbies (Support forum) | 11 | 12-05-2006 07:44 AM |
| How Loud is a router? | CNC Brute | DIY-CNC Router Table Machines | 19 | 12-10-2003 07:25 PM |
