Old 01-12-2005, 01:46 PM
plascom is on a distinguished road
Question bridgeport spindle motor replacement 1phase
does anyone know what motor can be put on this with out buying from bridgeport needs tobe 1phase. any help is always apreciated.
Old 01-12-2005, 01:59 PM
HuFlungDung's Avatar
Moderator
You could take the existing motor down to a motor rewinding shop. They can perhaps repair it, or look up a replacement that will fit.
Old 01-14-2005, 12:21 PM
gus gus is offline
gus is on a distinguished road
You are probably better off getting a phase converter. What are really nice are the VFD's that act as converters, variable speed and single phase input. YOu can also build a rotary converter very cheaply. Never buy a static one, junk
Old 02-13-2005, 07:38 PM
smallplanes is on a distinguished road
bridgeport 1 phase motor
I also need a single phase motor for a bridgeport style mill. Or where can i buy a phase converter from? How can i make a phase converter?
smallplanes
Old 02-13-2005, 10:40 PM
murphy625 is on a distinguished road
OEM Motor
A friend of mine asked me to get a replacement for him once for his mill..
The motor was a 3 phase but it didnt matter.. What made it special is that the OEM has the motor manufacturer make modifications to the motors design.
The only place you will normally find a replacement is the equipment manufacturer.
I do not like having to buy motors from the equipment manufacters because they jack up the price way to far.
Gusher Pumps are famous for this. Try replacing a motor on a Gusher pump. LOL
Are you trying to replace a burned out motor? Or just trying to make a 3 phase machine single phase?
good luck!
Old 02-14-2005, 12:03 AM
Moderator
machintek is on a distinguished road
BPT had a single phase motor for its J head (step pulley) but it was very costly. Since this head was phased out a few years ago, I do not know if the single phase motor is even available. I do not remember a single phase motor for the 2J head being available but I will check. If anyone has the maintenance manual, they list replacement parts in a section in the back (including motors). I believe it is possible to find a single phase replacement motor for the old J head. Fife-Pearce has a lot of BPT motors and parts. They may also have one.
In simple terms, a rotary phase converter is a static phase converter running a 3 phase motor hooked in parallel to your 3 phase BPT motor. I have seen some very reasonably priced on Ebay. A static phse converter is a box that artificially creates a 3rd leg for starting a motor, then it drops out. Needless to say a 3 phase motor does not have the same HP running on single phase as it does running on three.
George W.
Old 02-14-2005, 12:43 PM
Do you think i might could have the motor rewinded for single phase? Do you think i could get a replacment motor for a mill sold by Harbor freight tool that is a single phase motor? I have not got the mill yet i'm thinking of buying it from a friend here in town. I think i can get it at a good price. Thanks for the help.
smallplanes
Old 02-14-2005, 02:07 PM
Al_The_Man's Avatar
If you have a 220vac three phase motor right now, and only have single phase, then there is a couple of options, buy a VFD, this gives you the advantage of retaining the superior 3 phase motor and also having variable speed control, or go with a 1ph to 3ph converter, no speed control but you could run other 3ph equipment off it. For practicle purposes 3ph motor cannot be rewound for 1ph.
Al
Old 02-14-2005, 06:07 PM
Al_The_Man's Avatar
smallplanes
This is a recent link where I posted the info from when I made my 3ph converter.
CNC and phase converters
Al
Old 02-15-2005, 11:13 PM
What is better a VFD or a rotary phase converter? Does anyone know where i might find a used one for a good price? What about the static phase converter are they not any good?
Thanks for all the help
smallplanes
  #11   Ban this user!
Old 02-16-2005, 05:53 AM
NBrigode is on a distinguished road
I would only buy/build a rotary converter. Static are junk. We had one and it always seems to get hot. if your going to have a lot of equipment buy a bigger converter to start with. E-bay might have them. We stepped up from a 3hp static to 3hp rotary to 20+hp that we built. Bought a motor off e-bay and all the start and run capacitors also off e-bay. Our 20+ cost us about $300, which is cheap compared to $1,200 to 1,500 when you get that big. I want to say 250 is what we payed for the 3hp rotary. Its all is a matter of skill set, time, and the always deciding factor money.
Hope this helps,
Nick
Old 02-16-2005, 08:57 AM
Al_The_Man's Avatar
The VFD gives you speed control if you need it, down side - one machine only.
Rotary converter, simple & cheap to build, no speed control but mutiple machines can be run off it, Load hp can be 1.75 x rotary conv hp. with largest motor being no larger than conv. hp.
Al
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 03:57 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Mill spindle repair? kong General Metal Working Machines 6 04-02-2005 01:01 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 10:41 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 12:46 PM
