Old 04-01-2009, 02:05 PM
bherr is on a distinguished road
Question Setting Software limits
BP SeriesII Interact 4-Finally got the encoder problem fixed and now I need to set my software limits, but not sure which to use. ACTL, REF,NORMAL,DIST. Looked in my manual but couldn't find which one to use??? Guess I'll also have to adjust the LAG as well?
Ben
Old 04-05-2009, 11:31 PM
mcwmah is on a distinguished road
Use the REF as you software limit. I am not sure about the LAG but i think u need to adjust too. It is the bal between the X and Y axes.
Hopes it helps.
mcwmah
Setting Limits In TurboCNC? Also convert line drawings? Patrick_M TurboCNC 3 10-02-2008 12:21 PM
need help with limits and tunning Claude Boudreau Mach Software (ArtSoft software) 0 06-05-2007 06:14 PM
Out of limits monte55 Machines running Mach Software 7 11-04-2006 09:28 PM
we all need limits! senor J. General Electronics Discussion 28 08-24-2006 12:06 AM
limits jc286006 TurboCNC 2 09-08-2005 05:05 PM
