Old 03-30-2009, 03:27 PM
bherr is on a distinguished road
Question Phase balance a encoder
Talked with Heidenhain today after installing another ERO 115-125 encoder that I got from keith here on the forum. Found out that you need to have a phase meter to align the light emitting diode with the wheel, etc. Anyone ever done this and what is a phase meter?
Ben
Old 03-30-2009, 04:04 PM
Al_The_Man's Avatar
Fancy name for a double beam 'scope!
Many years since I did this, it used to be the norm on early Ferranti-Packard scales that had incandescent light source.
The method we used involved inputting one channel output (A) into the scope X input and the other (B) into the Y and produce a Lissajous figure to produce and indicate the exact 90deg difference.
http://www.jmargolin.com/mtest/LJfigs.htm
In the link shown, you need the full circle.
If no one here has the procedure for your encoder, I suggest you contact Heidenhain, they should have it.
Old 03-30-2009, 04:15 PM
gus gus is offline
gus is on a distinguished road
re
never heard of such a thing
Old 03-30-2009, 04:17 PM
Al,
I got a dual trace scope, so I guess I'll need to contact rick at Heidenhain. thanks for the heads up. You defiantly are the Man!
Ben
Old 03-30-2009, 04:32 PM
Al_The_Man's Avatar
Fortunately current quadrature encoders do not require this procedure, in the field, anyway.
Z Axis Counter Balance JerryFlyGuy Mechanical Calculations/Engineering Design 59 12-22-2011 09:58 AM
How to balance voltage on 3 phase? bherr Phase Converters and VFD 11 12-26-2010 03:26 PM
Pinch (Balance) Turning? sidswiss CNC Swiss Screw Machines 9 03-27-2009 02:45 AM
Voltage Balance lmarkie Phase Converters and VFD 4 05-16-2008 10:10 AM
Z Axis Counter Balance??? bio_eng DIY-CNC Router Table Machines 6 12-05-2003 01:13 PM
