Hi, my name is Peder and this is my first posting on this forum. I must say I find the forum very useful. I am the proud owner of a 1997 Romi Bridgeport EZPATH-S with a DX 32 control. I have a problem with the thread cycle, not the initial cycle which performs ok, but repeating the thread cycle is a problem. When I repeat the cycle it misses the threads. Have anyone come across this problem and have found a solution as to how I can solve it? Thank you very much in advance for your help. BR//Peder (Norway) |
Hello Peder, When you say you are repeating the cycle. What are you referring to? Is this the next part? Or are you repeating the cycle to cut the threads deeper? What exactly do you mean by misses the threads. I have the same machine. |
| Hi,it is when i repeat the cycle to cut the threads deeper! Have also discoverd that the spindle speed is 10-15% of. When i set the speed to 500Rpm, the control say 500Rpm. But when i measure it, it is actually 512Rpm,and stable. Missing the threads: It dont hit the threads dead on,it hits the threads half a thread of. Havent don threads for some time,4months or so.And everything workt ok before. Best Regards. Peder Thanks for your Reply! |
| hiya peder.although, im new both to CNC,ing & this site i mayebe able to help.are you using a G76 multiple thread cutting cycle? & are you remembering to cancell your G96 constant speed surface.the problem could also be with your cutting speed being too low,although i dont know what material your machining,& the number of passes your using,also check your feedrate isnt too high or two low.you can check the pitch you require & set the feed rate accordingly |
| Bridgeport/Romi EZPATH Schematics | NC Cams | Bridgeport and Hardinge Mills | 5 | 06-24-2011 06:00 PM |
| Bridgeport EZpath lathe | camtd | General Metal Working Machines | 0 | 02-16-2009 02:55 PM |
| EZPath II CSS problem | Gncc50 | Bridgeport and Hardinge Mills | 1 | 11-22-2008 12:43 PM |
| Bridgeport EZpath Axis fault | klxrcr | Bridgeport and Hardinge Mills | 2 | 09-30-2008 08:48 PM |
| Bridgeport EZPath help needed! | VSMIGuy | General Metal Working Machines | 1 | 01-08-2007 05:58 PM |
