Old 01-07-2005, 07:42 AM
masspfei is on a distinguished road
Boss 8 Error 4000
I found and corrected my axis limit error, and am now confronted with a new one.
When enabling the axises, it get error 4000. Looked it up in the book and it requires a field technician.
I hear the motors turn on, when I look inside the cabinet, x & y fan is going on top of the driver, but the z fan is not. Could this be the problem?
Was to late last night to do much research, but will get to it tonight. Any ideas?
TIA
Steven
Old 01-07-2005, 08:01 AM
Moderator
machintek is on a distinguished road
An Error 4000 Is A Axis Drive Fault. Check The Drives In The Black Cabinet On The Right Side Of The Machine. Each Has A Red Led To Indicate A Fault Or That The Drives Are Off. Have Someone Enable The Drives And See Which Leds Go Off And Which Stays On. You Will Have About Half A Second. The Drive With The Led That Stays On Is The One With The Fault. Remember That It Can Be The Motor Or Drive Or Cable. The Drives Slide Out. Exchange Two And See If It Follows The Drive Or Stays In The Same Axis. If It Follows The Drive, It Is The Drive. They Are Fragile Electronically.
George
Old 01-07-2005, 08:15 AM
Sorry, I should have been more specific in my post. All of the drives (3) have the red fault led on.
There is no A-Axis.
Steven
Old 01-08-2005, 11:56 AM
Moderator
Sorry, I capitalized the "a". Perhaps it should state "an" axis drive fault. Yes, I expect that the LEDs are on. Watch them carefully and see if when someone turns the drives on, that two of the three go off. If none go off, then there is an immediate error. I have to look at the prints to find the fault lines and see how to fool the control to keep the drives on to see which axis is at fault and which can move.
George
Old 01-08-2005, 12:00 PM
I am in the middle of hooking up the fist monitor. Will this help in this situation? I also replaced the fan that was not working. Luckly, had another bridgeport here to rob off of. It was broke...
Keep on sending suggestions, I have my pc up and making noise when I get messages.
Thanks,
Steven
Old 01-08-2005, 12:07 PM
Moderator
It may show you which axis is actually sending the fault. I have to read my notes.
George
Old 01-08-2005, 07:20 PM
I messed with the cabel half the day today, with no luck. The fault is instant.
Can I disconnect the cables off of each motor at a time to see which motor, cable is at fault?
Steven
Old 01-08-2005, 08:14 PM
Moderator
You cannot disconnect the motor cable(s). The axis drive board monitors the motor and this will create a fault. This will make the proverbial water more muddy.
According to the wiring schematics the axis drive gets 15VDC from the DLI board. On the X axis,it comes in on terminal 20 (wire 382). The axis drive outputs a fault at terminal 17 (wire 360). I do not know if the fault signal is high or low. Meaning that either 15VDC at wire 360 creates a fault or the lack of 15VDC creates a fault. The same terminals apply to the Y and Z axis. You can try pulling the wire off of each drive to see what happens or try jumping 17 to 20 on each drive one at a time to isolate which drive is at fault. I noted that there are seperate inputs to the FMDC which means the fist event monitor can indicate on which axis the fault lies.
George
Old 01-08-2005, 08:56 PM
HuFlungDung's Avatar
Moderator
Wouldn't it be funny if all it was, was the E-Stop button was locked in?
Old 01-08-2005, 09:32 PM
eman5oh is on a distinguished road
E-stop stuck in? Been thier and done that. Funny thinking back on it but not at the time.
Old 01-08-2005, 11:47 PM
Moderator
I wish it could be that simple. Unfortunately the 2 line LCD display can tell you that. If the control says error 4000, then unfortunately it is error 4 in the first set that translates to an axis drive fault. Seen it many times and it usually meant I had to slide in a new drive. Trouble is, this drive is obsolete. Maybe EMI has a replacement. It was also used on the BTC-1 machine. The next machine, the BOSS 9 used drives designed by Jack Lawler of Bridgeport Controls in Horsheim PA and built by Bridgeport.
George
George
  #12   Ban this user!
Old 01-09-2005, 11:13 AM
BTW, Checked the e-stop. Been burned before on a fanuc....
Steven
DNC with parallel port (Bridgeport BOSS 5)? hobbymat General CAM Discussion 3 07-20-2009 12:16 PM
Need so Bridgeport Boss education. AAA Bridgeport and Hardinge Mills 10 08-01-2005 08:39 PM
Bridgeport Boss Retrofit help moto21 Bridgeport and Hardinge Mills 7 06-09-2005 11:32 PM
Boss 5 help needed rsr911 Bridgeport and Hardinge Mills 4 10-27-2004 01:10 AM
How To; troubleshoot an Axis problem on Bridgeport BOSS inthedark Bridgeport and Hardinge Mills 0 03-25-2004 08:35 AM
