Old 03-25-2009, 12:25 PM
Minnesota HD 10 is on a distinguished road
Talking servo drives
Would like to know if anyone has or knows how to use bridgeport servo drives (boss 10) @ encoders with a BOB. Can the encoders be hooked up to a BOB or is their some other kind of board that can be used between encoders and BOB. The gecko drives run at 80vdc the bridgeport drives run at 130vdc whitch will run servo moters faster.The bridgeport drives are easy to hook up except for encoders whitch were hooked up fmdc board that is know longer functional.
thanks
hd10
Old 03-25-2009, 12:37 PM
bleky is on a distinguished road
hello
Old 03-29-2009, 07:07 AM
TOTALLYRC is on a distinguished road
If the drives that you want to use are analog input, try the dspmc controller that I use.
BTC-1 retro fit using DSPMC/IP controller.
Mike
Servo drives and PLC's? DennisCNC Servo Motors and Drives 4 12-30-2007 09:25 PM
servo drives help bbrreid Machine Problems, Solutions , Wireless DNC, serial port 0 11-09-2007 03:55 PM
Inexpensive AC servo drives? PeteZ28 Benchtop Machines 1 03-01-2006 06:52 PM
Servo drives quickerz Servo Motors and Drives 1 01-21-2005 11:24 AM
New servo drives? CNCadmin Servo Motors and Drives 1 12-25-2004 09:47 AM
