  #37   Ban this user!
Old 03-27-2009, 09:15 AM
Woody111 is on a distinguished road
If you have not sent this motor out yet I know of a shop in the Pittsburgh PA area that has alot of experience with SEM motors. The are a dedicated servo repair shop and can realign encoders remag motors and they offer a free evaluation. Only cost you shipping. If need a name and phone # contact me at 814 720-5336 leave a message. Woody
Old 03-27-2009, 09:21 AM
Al_The_Man's Avatar
Originally Posted by joejared View Post
Should you install a different encoder and the coordinates are backwards, exchanging the A and A- lines with B and B- will correct the problem.
Also swapping A and A\ will do it.
  #39   Ban this user!
Old 03-28-2009, 09:42 PM
joejared is on a distinguished road
Originally Posted by Al_The_Man View Post
Also swapping A and A will do it.
True, but don't you also need to swap B and b- as well?
norm = inverted A
A/B A-/B
00 = 10
01 = 11
10 = 00
11 = 01
It appears that the motor will go in the same direction with A inverted.
AB = A-/B-
00 = 11
01 = 10
10 = 01
11 = 00
Both A and B channels need to be flipped, either in using the inverting signals, or by way of exchanging A and B entirely. For non-buffered chips, A and B would need to be swapped, which might lend credibility to being consistent in methods.
Old 03-28-2009, 10:32 PM
Al_The_Man's Avatar
No, done it many times, swapping one changes the phase relation from leading to lagging or vice-versa for a given channel and direction.
  #41   Ban this user!
Old 03-29-2009, 06:50 AM
bherr is on a distinguished road
Woody,
good to know. I've got a replacement encoder coming and should be here on Monday. Keith out of Mass. had one.
Ben
  #42   Ban this user!
Old 04-13-2009, 09:33 PM
ricardo_avila is on a distinguished road
I have exactly the same problem as you did. Same encoder, Y axis, Bridgeport Interact 412. What did you do? Did you part with the $300 to $600?
  #43   Ban this user!
Old 09-21-2009, 03:47 PM
sclark58 is on a distinguished road
Sclark
This site is great! I have had a number of calls. The foto is an ERo-115 type encoder. The line count may be 125 or 200. The were used on the old Bports made in the 1980's. There are alot still out there. We typically find a short has taken out the referance signal. Sometimes it only needs to be cleaned-up to get out the graphite dust.$317 is the cost to reurbish the motor to factory spec.
Encoder / Servo stevo1 Fanuc 0 07-10-2008 01:06 PM
gecko / servo / encoder wiring shnitzel Gecko Drives 2 07-18-2007 06:02 PM
servo encoder question CNC Darren Servo Motors and Drives 0 03-08-2007 04:20 AM
servo encoder placement? tooManyHobbies Benchtop Machines 0 12-01-2006 12:46 PM
servo verses dc with encoder phil spanner Servo Motors and Drives 8 03-27-2006 06:20 AM
