Old 03-20-2009, 08:07 PM
joanpim is on a distinguished road
Bridgeport comunication problem
Hello,
I have a Bridgeport R2E3 with Boss 8 control. For some reason, serial communications with the PC have failed. I have tried a new PC and another communication program, but no luck. Does anyone have any ideas for or experiences with this type of problem?
thanks in advanced
Joan,
Old 03-21-2009, 11:06 AM
Moderator
machintek is on a distinguished road
I use a DOS version of PROCOMM (shareware from ages ago) to communicate with these old machines as well as Heidenhain and Fanuc.
It has terminal or chat mode. When going into edit from port A (assuming everything is correct (cable, handshake, and hardware), the PC will display BOSS 8 EDITOR if a program is in the machine or BOSS 8 INPUT if the memory is empty.
This at least shows COMM in one direction and that everything is OK in that direction.
I carry a Radio Shack RS232 tester which is nothing more than a serial device placed between the PC and the cable. It has LED on it for the important comm lines. These light up and if I send a program will flicker. If the LED flicker the PC is sending data. If it has the correct format, the machine should receive it. If not there may be a issue with the EAF board which receives the data.
Back in 86 when I had a BOSS 9 I eventually used the EZCAM based on the MAC to generate programs, but I used a TRS80 Model 100 for editing right at the machine. Using loops and macros I could condense a 8 page program to less than one page for multiple parts. IE 4 parts per vise with 2 vises on the table. CAM systems are very generous with code but these old machines did not have a lot of memory. My EZCAM did not support cutter comp, so I had to edit programs to insert that as well.
George
Old 03-22-2009, 05:31 PM
DF-ENTERPRISES is on a distinguished road
EMI
You might want to try EMI and get a mother board kit.
Old 03-22-2009, 05:52 PM
cadcamsolutions's Avatar
cadcamsolutions is on a distinguished road
Thanks George, for you reply, i need a ezlink.zip copy if you have i appreciated you send me a copy of this software is very importan for my
joanpim@hotmail.com
thanks in advanced
joan
Comunication problem Alex S.A Machine Problems, Solutions , Wireless DNC, serial port 4 03-31-2011 04:25 PM
Need Help!- Comunication problem VTC-41 Jcip Mazak, Mitsubishi, Mazatrol 1 03-20-2009 05:49 PM
Fagor RS-232-comunication. GPena Fagor Automation 1 12-21-2007 08:22 PM
Fanuc 18 serial comunication problem profe06 Fanuc 2 08-10-2007 11:32 PM
mitsubishi comunication rosli Servo Motors and Drives 3 05-27-2006 05:14 PM
