hi everybody this is my first go and its a problem i have the deadly series 1 with a boss 6 control and it has stoped driving in x axis the stepper motor tries so i have replaced the faulty diodes which then it seems to blow 5 diodes later im out of ideas |
I had a lot of problems with blowing transistors when I first got my boss 6 mill. Make sure you have leads hooked up correctly. Also you can move another axis board into a non working axis. Listen closely when you get new transistors in power supply and see if you can hear speed of motor slowing down before motor stops as motor is supposed to ramp down speed before motor stops. Otherwise you will get transistors shorting. I had a circuit board messed up when I first got my boss 6. Do you have an X-Y-Z check list? If not I can scan mine and email you a copy if I had your email address. kw grigsby |
| thanks for that info i'm going to get my head stuck in the m/c over the next few days the xyz check list sounds ok if you can email it to gerry@leedsvacform.com watch this space |
| Need Help!- Bridgeport S1 BOSS6.1 No Jog or Edit mode | NeophyteJay | Bridgeport and Hardinge Mills | 5 | 10-22-2008 08:20 AM |
| Simple, 3 Axes with Dual Drive/Motor (per axis), hardware splitter drive Interface. | kreutz | Stepper Motors and Drives | 3 | 07-03-2008 07:57 PM |
| Boss6 X-Axis Metal Bellows Replacement | snakebit95 | Bridgeport and Hardinge Mills | 4 | 07-04-2007 05:52 PM |
| Bridgeport BOSS6 SMD controll | Phooey | Bridgeport and Hardinge Mills | 4 | 06-16-2005 09:21 PM |
| Trying to drip feed a cnc boss6 bridgeport | cncboss6 | Bridgeport and Hardinge Mills | 2 | 03-11-2005 07:28 PM |
