Old 03-17-2009, 09:54 PM
TWKundrat is on a distinguished road
Bridgeport R2E3 Problems
I just got an old Bridgeport series 1 r2e3 milling machine with Boss 8 control and I am running into some problems getting the machine to work. I do not have the maintenance manual yet because I am on a budget. Does anyone know what the difference is between the the series 1 r2e3 and the series 2 r2e3? I have found the series 2 manuals for much cheaper. As far as the machine goes, when I turn on the power the display reads "error 2000" and I am unable to jog the machine or turn on the spindle, or anything else. I have made sure that none of the limits switches are activated, and I have checked the computer for loose or dirty connections. All of the fuses that I have seen were checked but still no luck. The thing that I am curious about is that the fans on the servo drivers are not running leading me to believe that they have no power. I have been told that you can plug another computer into the cable coming out of the electronics box to run a diagnostic check. If anyone knows where I can find the codes to allow my computer to talk to the machne that would be helpful. Any ideas/info would be greatly appreciated!
Thanks,
Tim (Tucson, AZ)
Old 03-18-2009, 08:42 PM
Kevin Taylor is on a distinguished road
George aka Machintec is your best hope First check power supply voltages I think that the 3 is series 1 iron and the 4 is 2 the controls are simaler to my BTC 7.2 I'v looked at some and I think they have the same servos and the control is much the same but to be sure try to p.m. George he post's in the BPT fourm regulary Kevin
Old 03-19-2009, 08:37 AM
Moderator
machintek is on a distinguished road
Error 2000 is a internal communications error. A fatal error.
(Error 2 in set 1 or 4.)
May be power supply, board, or wire/plug related.
George
Old 03-19-2009, 12:21 PM
cut more is on a distinguished road
Error 2000
I had 2 of these that had the 2000 error. In my case it was caused by dead batteries.
One other thing to check, though probably not it, is that the oil reservoir is not empty. That will cause the spindle not to start and give an error.
I don't remember what error though as I learned to check the oil reservoir every time I run it.
Regards,
Cutmore
Old 03-19-2009, 10:07 PM
Thanks for the help, it turned out to be a loose solder joint on the power supply for the FMDC board
Bridgeport R2E3 Boss 8 Encoder problems leftyrowe Bridgeport and Hardinge Mills 8 11-23-2009 09:03 AM
Need Help!- Bridgeport R2E3 toadjammer Bridgeport and Hardinge Mills 2 02-19-2009 12:25 PM
bridgeport II r2e3 whaley Bridgeport and Hardinge Mills 3 01-06-2008 03:13 AM
Bridgeport R2E3 Need Help Got Problems paparandy Bridgeport and Hardinge Mills 3 05-19-2007 12:13 AM
Problems with DNC to BOSS 8 R2E3 rkdygert Bridgeport and Hardinge Mills 0 04-17-2006 09:45 AM
