Old 03-16-2009, 10:26 PM
Cartierusm is on a distinguished road
Clutch and Downfeed Removal for CNC?
Just want to know if I can permanently remove the clutch assembly for the down feed and the down feed gears to make it easier to design a Z axis for CNC.
I mean I want to know if I pull those assemblies out for good if it will mess up other gears and such. I take it if I can remove them I'll have to make an aluminum plate to block those areas off to keep oil in and dust out?
TIA
Old 03-17-2009, 12:11 AM
HimyKabibble is on a distinguished road
TIA
If you're not using the downfeed, those gears do nothing of value. It's not terribly difficult to remove them all.
Regards,
Ray L.
Old 03-17-2009, 03:20 AM
Thanks.
colchester student mk1 clutch help mycoolbeard General Metal Working Machines 7 12-04-2008 04:20 PM
Bendix clutch Chubs Jet Engines and Ram Jets 9 10-03-2007 12:02 AM
X Axis powerfeed clutch adjustment Stinson_Voyager Tree 1 12-27-2006 06:31 AM
found clutch mdreitzusa Mechanical Calculations/Engineering Design 7 10-01-2005 12:35 AM
Electic clutch Konstantin General Electronics Discussion 0 09-02-2004 01:12 AM
