| Helical Interpolation I have a V2xt with a DX-32 control. I have maint. manuals but nothing with list of G-codes supported. I have a thread milling job and was unsure if the dx-32 supported helical interpolation. If so does any one have the syntax used? Thanks Coop |
| Try adding a Z move to the G02/G03 moves.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| worked Thanks, It worked fine.Sometimes the answer is sitting right there . Coop |
| You are missing the programming and operating manual which lists the G and M codes. There is a "canned" G code to do helical. Helical means a certain Z distance move while moving in a G17 X and Y circular move and this Z move to be accomplished in a certain amount of degrees of a circle and you can increase or decrease the radius of the circle. The Bridgeport also supports a G79 which was a very quick and dirty way to do a circle with an arc in and out. Check with machinemanuals.net to see if he has a programming manual. George W. |
| Helical interpolation is G12 for CW and G13 for CCW. Requires a position move to start point using polar coordinates. G0(G1)R_ I_J_A_ G12(G13)A_Z_F_ A is the total number of degrees. Z is the Absolute Depth of travel. Cutter comp CANNOT be used. A range is from 1.0 to 65535.0 degrees. Helical cannot be transformed. SPIRAL INTERPOLATION use polar data to achieve a start and end radius that is different. Use same start line but: G12(G13)R_A_Z_F_ Now you have good data. George W. |
| Biesse Machine and MeshCam - HELP | nem3 | GRZ Software- MeshCAM | 11 | 09-28-2007 09:57 AM |
| helical milling | hogman | GibbsCAM | 4 | 04-21-2006 09:15 PM |
| Need Bridgeport EZ-Track G-Codes to build post | soweebee | Bridgeport and Hardinge Mills | 13 | 01-28-2006 02:10 AM |
| involute interpolation | utengineer04 | G-Code Programing | 0 | 04-26-2005 01:17 PM |
| interpolation | rimcanyon | General Electronics Discussion | 9 | 04-08-2004 02:10 AM |
