Old 03-10-2009, 10:26 AM
candylyn is on a distinguished road
CNC Bridgeport upgrade
I have a EX TRAK SX, 2 axis machine that I want to do the following to:
1. Add a Z axis, preferably on the knee and not the spindle.
2. Upgrade the control hardware and software to something more modern and user friendly, at a reasonable price.
Can anyone suggest a direction to go in?
Old 03-10-2009, 08:20 PM
masonbcaldwell4's Avatar
masonbcaldwell4 is on a distinguished road
I can get you a model no. in a few days, but Accu-rite makes an NC conversion which is extremly user friendly, is fully conversational and is very easy to learn. the only downside is that your Z is your spindle, coolant is under your control, as well as tool change and spindle speed. let me know if your interested.
Old 03-10-2009, 09:48 PM
TOTALLYRC is on a distinguished road
REasonable price???
I think $50 is reasonable, and the cnc guys that do it for a living may think $10k is reasonable. Please define your version of reasoanable.
For what I think most people think is reasonable would be the smoothstepper and Mach3 using a pc for the control. From one of the pictures that I saw on the web, it looks like it is a servo driven machine, which if it has anaolg servo drives could be a little more problematic. The dspmc/ip will handle the analog servo drives and has lots of inputs, and it is what I used on my retrofit.
If the machine currently runs, you can use it to make a motor bracket to drive the knee, and then retrofit it from there. I think Himmykabibal (sp?) has a clone that has the knee cnc'd and can go like 400"/min done with gecko's and Mach IIRC.
But it all comes down to what you want to do and what you want to spend.
Mike
Old 03-11-2009, 01:06 AM
HimyKabibble is on a distinguished road
CNC'ing the knee can work well, but it's not without its problems. That's a LOT of mass to move around, so it takes a LOT of power, and won't be fast. If you're going to do 3D work, the speed will kill you. The screws/ways will likely wear faster than normal. If this is for strictly for hobby use, that's probably not too much of a problem.
I did my knee, and I'm now working (slowly....) on doing the quill, at which point the knee will be used only for tool length compensation. The quill is a better, albeit slightly more complicated, way to go. I always planned to do the quill, but the knee drive was a very quick and easy way to get a third axis with minimal effort.
Regards,
Ray L.
Old 03-11-2009, 02:01 AM
Regards,
Ray L.
Slightly off topic, but I am sure that candylyn will be interested. My machine is the other way, the quill is cnc and I am working on adding the knee for tool length compensation. With only 5 inches on the quill, you can run out of travel fast.
I was wondering, can the tool length compensation be applied to the knee automatically, when using the quill for the z axis?
Hope I wasn't too far off on your machine specs, Ray.
Mike
Old 03-11-2009, 11:13 AM
Mike
Mike,
Yes, I've already written the Mach3 macros to apply tool length to the knee automatically. Let me know when you need them.
Its' my X and Y that'll do 400 IPM (though I don't run it that way - too scary). It'd take one helluva motor to get the knee going that fast - It only does 75 IPM.
Regards,
Ray L.
Old 03-11-2009, 03:51 PM
That is way too cool. Some day I will be able to program within Mach3.
I will contact you shortly as I plan on doing the knee conversion next week.
I had my mill going 200ipm on the quill and it is really scary in that the quill is only 5 inches travel.
I will hopefully have my knee go 30ipm, since it will only be for tool offsets, I won't need much in the way of speed.
Thanks,
Mike
CNC Bridgeport whatever model servo upgrade contractdesign Bridgeport and Hardinge Mills 0 01-29-2009 07:47 PM
Bridgeport Upgrade jaztau Bridgeport and Hardinge Mills 12 11-13-2008 09:54 AM
Bridgeport Series 1 CNC upgrade / retrofit chrispy Vertical Mill, Lathe Project Log 4 11-06-2007 04:54 PM
Bridgeport TNC150 to TNC151A upgrade UK Dave Bridgeport and Hardinge Mills 9 02-13-2007 10:42 AM
Bridgeport EZ Trak control upgrade. mailloux Bridgeport and Hardinge Mills 3 09-14-2006 09:53 AM
