Old 03-05-2009, 07:39 PM
davesnd's Avatar
davesnd is on a distinguished road
Heidenhain 4th axis
Hello - I am looking for somebody who has a Heidenhain TNC 155Q control with a working 4th axis who is willing to tell me the Heidenhain part# of the encoder that it uses. I am building a 16" CNC rotary table for my machine and need to find the correct encoder that will connect to the controller. Even better yet would be finding someone who wants to sell such an encoder....
Old 03-05-2009, 08:52 PM
gus gus is offline
gus is on a distinguished road
re
any heidenhain encoder of the appropriate vintage ought to work. There are parameters for type and line count etc. Doesn't have to be heid., but they will plug in
Old 03-17-2009, 02:56 PM
Jukka Honkanen is on a distinguished road
Encoder input
on the Heidenhain TNC155 has only to possibilities.
If the rotary encoder is fitted to the center of the table the line count must be either 18000 or 36000.
Those encoders are very expensive. If you fit the encoder to the motor then you need to calculate the ratio of the motor/table and come up with the same line number / table turn.
The signal of the encoder must be 11uApp (16uApp in the older version do well)
Jukka
Hermle / Heidenhain 5-axis accuracy greenchair General Metal Working Machines 4 03-17-2009 02:47 PM
Bridgeport s II interact II z-axis HEIDENHAIN bigtoad170 Bridgeport and Hardinge Mills 7 05-18-2008 08:15 PM
Heidenhain 155Q Problem with x and Y axis Zoni Machine Problems, Solutions , Wireless DNC, serial port 0 04-05-2008 05:33 AM
Problem- Five Axis Heidenhain Post TonyCarter0001 EdgeCam 0 03-25-2008 05:28 AM
Heidenhain 2500 - Programming Z Axis palikalsi General CNC (Mill and Lathe) Control Software (NC) 0 03-26-2007 09:46 AM
