Old 03-04-2009, 09:15 PM
rams_head is on a distinguished road
Communications Problem: PC--> Bridgeport Model R2E3 (BOSS 8)
Hi Everyone,
I am assisting a customer in troubleshooting a communications problem on a Bridgeport Series II Model R2E3 mill with BOSS 8 control. They have lost the ability to download part programs from their remote PC. The PC has a DNC setup by Predator Software and is connected to data port B on the mill.
I have checked the obvious things like communication port and baud rate settings along with a continuity check on the cable between the two. I have also verified that data is being transmitted from the port on the PC. The LED on the EAF board in the mill blinks green shortly after power up which I have read indicates it has passed its self-diagnostic check although I'm not sure what board functions are checked. Does anyone know of an easy way to use a terminal emulator to verify data port communications on the EAF board?
The one anomaly on the mill I have noticed is that when I execute a 'Load From Remote' command there is no asterisk located in the far left position on the bottom line of the LCD display. The operating manual states..."EXECUTE will enter the LOAD submode and a "*" prompt will appear at the extreme lower left portion of the screen." Anyone seen this before?
Any information would be greatly appreciated.
Thanks in advance,
Kenny
Need Help!- Bridgeport R2E3 Boss 8 Control machinistman Bridgeport and Hardinge Mills 3 12-12-2008 07:26 PM
bridgeport II/r2e3 boss 8 whaley Mechanical Calculations/Engineering Design 0 01-02-2008 12:02 AM
Need Display Bridgeport R2E3 with Boss 8 hrhoward Bridgeport and Hardinge Mills 2 11-26-2006 05:31 PM
Bridgeport R2E3 with Boss 8 John Bennett Bridgeport and Hardinge Mills 0 09-16-2005 08:35 PM
Bridgeport R2E3 with Boss 8 John Bennett Bridgeport and Hardinge Mills 5 04-06-2005 11:06 AM
