Old 03-03-2009, 05:46 AM
DaveinUK is on a distinguished road
Z axis keeps stopping on Boss 5
Hi All,
My machine keeps stopping in the Z axis during a programe, never the same point !! I have used the programe many times before with no problems. Any ideas where I should look for the possible cause. The machine has only just started to do this.
Thanks for your help.
Dave
Old 03-03-2009, 09:23 AM
Moderator
machintek is on a distinguished road
Final drive transistors.
Bridge rectifier.
High resistance in DC side fuse holder.
ACC (current regulation board) out of adjustment.
Quill getting gummed up.
George
Old 03-03-2009, 10:08 AM
Thank you George,
The machine works again, once I power down, then power up. I will check the areas you mention.
Dave
Need Help!- Boss 6 Y axis dead timprebleco Bridgeport and Hardinge Mills 2 01-01-2009 09:59 AM
Need Help!- boss axis problem loose1 Bridgeport and Hardinge Mills 1 12-16-2008 11:40 PM
Boss 5 no axis movement tom.jelly Bridgeport and Hardinge Mills 26 10-28-2008 02:34 PM
Series 1 Boss 5 - Keeps Stopping in Z Axis DaveinUK Bridgeport and Hardinge Mills 9 02-14-2006 06:32 AM
Boss 5 Y axis problem? jeaBOSS5 Bridgeport and Hardinge Mills 8 12-11-2005 04:40 PM
