I did a search, and could find much on this, so if there are links out there, or advice thanks in advance. The origional motor is 575V 3 phase, and because of cost, will be swapping it out. The easiest is changing to a 220V 1 phase 2 hp motor currently on sale. The other option is to swap in a Leeson DC 3/4 hp motor in order to have infinite speed control, but I know sweet nadda about Dc motor controller or drives. The motor is a 90 volt unit Would it also be possible to have an RPM display built in as well? Thanks, Ken J |
Keep the 3-phase motor, and buy a VFD - It'll let you run your 3-phase motor from a single-phase line, and give you variable speed - with display. For a 2HP motor, it'll cost you well under $200. (Look at the TECO FM50s at factorymation.com). Regards, Ray L. |
| Keeping the motor is probably not an option if it is 575v. You will need both motor and VFD if going that route. The 1 phase motor will not give you electronic variable speed. The leeson maybe well underpowered if it is only 3/4hp. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| The problem is the 575 voltage the origional motor requires, I need a transformer to step the voltage up from household 220. And the origional motor is 3/4 horse. Quotes are around 600 to 900 bucks for both a transfomer and a phase converter. Im not spending that. Even if I want to keep 3 phase, I have to get a different 3 phase motor. The DC motor was 80 bucks, I either use it here or somewhere else. The price of a motor drive should be less than the VFD. Basic internet search looks like about 100 to 150 for a drive board. With the DC you get all the power with the speed control. So my options are, 1) use the DC motor which I have from a trade, but need motor controller, which I know squat about..... 2) buy a 220V face mount motor currently on sale, and its 2 hp so lots of power, and I still have all the pulleys for the different speeds, as was the origional setup,,, bolt it up and go, but no reverse switching,, 3) find another 3 phase that fits, must be the right voltage,,, and then get a VFD KJ |
| you must have been reading my mind Al,,, question tho....... if the origional 3P motor was 3/4 horse,,, should a DC 3/4 not provide the same power (torque)?? if its underpowered, the 1P 220V 2 horse motor should have gobs to spare, and there are still the pulleys which were needed to use with the origional motor. KJ |
| I see you have a duplicate thread going, now you mention the original was only 3/4hp you could use the DC motor, you need to get a KB or Baldor DC drive. These can be had on ebay. Or from you local KB/Baldor rep. These do not normally come with speed indication as does a VFD, although a VFD only indicates the speed (frequency) it is outputting, unless it has the encoder option, it is not exact rpm. Al.
http://www.surpluscenter.com/item.as...tname=electric - you'll want the heat sink for it as well. http://www.surpluscenter.com/item.as...tname=electric They also have a number of 3-phase motors for cheap. Regards, Ray L. |
| Can I convert single phase motor to three phase? | Jim Estes | Phase Converters and VFD | 30 | 01-24-2009 03:41 AM |
| swapping bearings????? | the4thseal | DIY-CNC Router Table Machines | 7 | 12-12-2007 08:20 PM |
| 2.5 amps per phase drive - 2.8 amps per phase bipolar motor ... | kochevnik | Stepper Motors and Drives | 6 | 10-22-2006 11:48 PM |
| Understanding swapping tools for a job | dneisler | General Metalwork Discussion | 8 | 02-16-2006 03:55 PM |
