#13
![]() Good stuf. ![]() Owen
__________________ 9 1/2 B.C.I.T. Machinist CNC |
#14
| No prob. If you can't sort it out, let me know, and I'll dig out exactly what I did to get it going. The basic idea is to just keep it powered until the motor slows down. Mine only faulted whe it was shut off above about 4K RPM. Regards, Ray L. |
#15
This is the kind of stuff I'm worried about. Maybe I should just use the bridgeport switch to turn it on and off? I never run in reverse on that machine and I can count the number of times I've used low gear. In almost 5 years, I had one job on a brigeprort that i felt the need to power tap holes on the fixture/set-up. Every other hole is tapped as a secondary opp. Plus, I guess power tapping will go out the window with the VFD? Guess I would need to knock the dust off my tapping head, if I can find it ![]() But it would be nice if MACH3 would have control over the spindle speed and on/off. Could slow the speed for plunging with an enmill and truley run "lights out" instead of eventually having to come back and shut the machine off, or atleast the spindle... |
#16
| And is it possible to just use the normal spindle switch to turn the VFD on and off, even if it's only 1 direction? I honestly can't remember how the HIGH/LOW or On/Off factory switch works, I would have to pull it apart and look, I was just wondering if you guys knew off the top of your head. I know its purley a mechanical contact, but I'm not sure if I would be able to wire the VFD ON and direction low voltage wiring throught the BP switch. It's a variable speed head, even at 120hz, I could just divided the speed by 2 and adjust at the machine. Just a thought. |
#17
If you have a two-speed motor, you just have to be sure to never touch the speed switch when the VFD is actually driving the motor. Regards, Ray L. |
#18
| Generally with VFD's you get what you pay for, the more features, the more money. One feature you could use is multi-speed feature, three contact closure inputs gives you 8 presetable speeds. If you want to control from Mach instead of PWM to analogue. Another upper end feature is automatic tuning to your particular motor characteristics for better control. Al.
#19
Of course, with *any* VFD you can create that same functionality with nothing but relays and resistors to set the VFD control voltage. Regards, Ray L. |
#20
| Although it might get tricky to produce 8 speeds from three contacts. Al.
#21
| Regards, Ray L. |
#22
The Hitachi sj200, 3hp that I am using works real well and has multi speed steps that can be programed in. In regards to the stop and start faults, all you have to do is set the accel and decel times in the drive and I have not had a fault since. If you need it to stop really fast or you have a lot of spindle mass, you will then need to get braking resistors. Mine will start in 1 sec and stop in under 3 if I remember correctly without resistors on my btc-1. You can also program in the amount of overload up to 150% of normal to help with the starting problems. In response to the manual is designed to be read by engineers, I agree, and the $120 pc programing cable from Hitachi is a joke. ![]() I would love to program it from PC, but $120 for convience is just not going to happen, unless someone knows the pin out since it is just a serial connection, but it has a db9 on one end and a rj-45 on the other.The software is a free download from hitachi.
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
#23
| to answer your question yes you can use the stock bridgeport switch to control the vfd. it is very simple. i didn't want to mess with my switch and i use my vfd for my mill and lathe so i just made a switch box from a regular remodel box with a normal light switch and a 25K ohm linear pot for $2.50 from radioshack. i have velcro on the lathe, mill and box and just move the box to the tool i'm using. for reverse i use the switch on the tool, just make sue you never reverse or turn off when the vfd is running. about 20% chance smoke will come out. |
| cat 5 network hook-up for DNC ???????? | krfrea | Computers and Networking | 3 | 10-15-2007 07:53 AM |
| Where does encoders hook up? | jimluu | Stepper Motors and Drives | 2 | 05-19-2007 09:15 PM |
| Drive has CW/CCW, need to hook to LPT | foam27 | Stepper Motors and Drives | 5 | 05-19-2007 08:25 PM |
| C-Hook programing | Russler | Mastercam | 1 | 01-14-2007 08:56 AM |
| C Hook | Graphcon | Mastercam | 5 | 01-11-2005 01:06 PM |
