Hi everybody. I have been having some problems. When I start my spindle running about 1500-2000 rpms the spindle starts good. When I try to start it with 2500 plus RPM's I get a drive fault or spinlde overload error. I can start it at 2000 RPMs and bump it up to 3000 or higher with no problem. Any comments will be helpful. Thanks DF |
| Current draw vs time to get to speed and the current drops is too great. Do you have true 3 phase power? Are you on a phase converter? Static or rotary? What is the spindle motor overload set to? Is the spindle motor wired for the correct incoming voltage? George
| I am running a American Rotary 5hp phase converter. I tried adjusting the spindle overload from the lowest to the highest setting but that didn't help. Originally I had a Bridegport tech wire the machine for 230 volts. Is there a way I can check an area with a voltmeter at startup to see if the voltage is dropping to low? I'm beginning to think a phase converter is not a reliable way to power this machine. Thanks George. |
| If you measure each leg with respect to ground with a voltmeter, probably the artificial leg goes way low when you start up the spindle. There are a lot of posts about this. George
| Problem- SPINDLE AXIS DRIVE FAULT | homezz | Haas Lathes | 1 | 10-04-2009 11:25 AM |
| Spindle drive fault | Peat | Cincinnati CNC | 5 | 11-08-2008 02:02 AM |
| Hass VF-0 Spindle Drive Fault Q's, HELP! | Ryan Moore | Haas Mills | 7 | 05-31-2007 05:45 PM |
| Alarm 123 Spindle Drive Fault | Shotout | Haas Mills | 11 | 05-27-2007 12:48 PM |
| Spindle Drive Fault | n5jjr | Machine Problems, Solutions , Wireless DNC, serial port | 15 | 03-31-2005 09:26 AM |
