In retrofiting boss 10 on a series 1 bridgeport to mach 3, what would be the disadvantages or advantages of using the boss 10 power supply,24 volt system for the axies drives and moter contactor. thank you very much for your replies minnesota hd10 |
| I have a boss 9 which i don't think its too far off from a Boss 10. If you are technical enough to use all the old power supplies then you will be way ahead of the game. All the PS's are setup up perfectly for each component on the machine. The problem is figuring out where all the wires lead too. Since you are retrofitting it you have to bypass the old controller and use BOB. It starts to get challenging when your dealing with 3 phase power stepping down to 1 phase. My Boss 9 had about 9 different power supplies and most of them were all different sizes, and was just too confusing to me figure out what goes where. I ended up using all new PS for everything and it has made it much easier knowing what I'm using. |
dirtdiggler thank you for the reply. I have not started this retrofit yet, i do have all of the electrical diargrams for this machine and know where the wires go. not all that sure i know how to hook up to breakout board. I have been researching this for some time but have not sean much about wiring configerrations. thanks minnesota hd 10 |
| BP boss retrofit? | sdeering | Bridgeport and Hardinge Mills | 21 | 12-17-2011 09:40 PM |
| Boss 9 retrofit advice | dirtdiggler | Bridgeport and Hardinge Mills | 4 | 12-01-2008 01:23 PM |
| Retrofit questions Boss 5,6 | cabledude | Mach Mill | 2 | 11-26-2007 06:16 PM |
| Retrofit kits for Boss 6 | DaveinUK | Bridgeport and Hardinge Mills | 1 | 09-19-2007 05:57 PM |
| Bridgeport boss retrofit | cat37 | Bridgeport and Hardinge Mills | 1 | 08-21-2007 09:46 PM |
