Old 02-20-2009, 09:41 AM
Neil Mckillop is on a distinguished road
Eztrak DX II lube problem
Got a problem with my Eztrack DX II lube system. The pump seems to work but very little or no lube appears on the bedways. It pumps ok up to the point where the pipe disapears into the saddle. I've tried pumping lube through it with a hand pump but not much comes out. Is there any way of cleaning the lube pipes without removing the bed?
Old 02-22-2009, 12:47 PM
colin1544 is on a distinguished road
Eztrak lube problem
Hello Neil I have just bought an EZPLUS which is the later version of yours, with it I got the lube pump instructions, check to see if the manual knob pulls up and rotates if it does then turn it anti-clockwise while lifting up and this increases the amount of oil per pumped per motor revolution and if it also has a pressure gauge you will see the pressure increase as well. if you need a natter about it please ring 01159389014 (Nottingham) Cheers Colin.
Need Help!- Bridgeport EZtrak startup problem premierpatterns Bridgeport and Hardinge Mills 15 01-27-2010 04:37 AM
Problem with my EZTRAK 3-axis Ingchema Bridgeport and Hardinge Mills 1 09-21-2008 02:47 PM
Problem with my EZTRAK 3-axis Ingchema Trade Shows and Events 0 09-16-2008 08:59 AM
EZTRAK DX II Problem JPMProto Bridgeport and Hardinge Mills 8 06-13-2006 10:12 PM
eztrak sx problem(s) DGeoLab Bridgeport and Hardinge Mills 2 05-20-2006 10:18 AM
