I am getting an "Axis Limit" fault when executing a rapid move with the Z-axis. It seems to occur after the Z-axis makes a rapid move of anything greater than a half inch or so in either plus and minus directions. The fault is random, sometimes I run the machine for an hour without a fault, sometimes it will fault 6 or 8 times an hour. But it is slowly becoming more common. So whatever the problem is, it's getting worse. When the fault occurs I re-enable the axis drives and re-home the machine and everything runs as it should until the fault occurs again. I checked the servo controllers and didn't see any alarm on those. The green lights on the FMDC board are blinking as they should. I checked wire connections on the Z-axis home switches, all those looked fine. Motor cables are tight. Could this be encoder or motor problem? Anyone have any ideas? Thanks in advance. |
| Problem- Intermittent x axis failure | ronateah | LinuxCNC (formerly EMC2) | 32 | 02-25-2009 07:15 PM |
| Deckel Maho DMC 63V Z axis intermittent drop.................need help | alimansyah | Deckel, Maho, Aciera, Abene Mills | 13 | 10-15-2008 11:41 AM |
| BP R2E3 S1B8 Z-Axis limit switch | cidteach | Bridgeport and Hardinge Mills | 4 | 09-25-2007 10:47 PM |
| R2E3 Boss 8 Axis limit problem | hrhoward | Bridgeport and Hardinge Mills | 4 | 05-30-2007 09:24 PM |
| R2E3 Z limit switch part numbers | hrhoward | Bridgeport and Hardinge Mills | 5 | 05-23-2007 09:05 AM |
