  #13
Old 02-01-2011, 07:50 PM
Moderator
machintek is on a distinguished road
Yes. Did you try it? Did it fix your issue?
George
  #14   Ban this user!
Old 02-02-2011, 06:09 AM
jorber's Avatar
jorber is on a distinguished road
Red face Solved
Yes, I have the handle OP03A, in this one the Jog button must be replaced by Mode/set button.
Now I am looking for the users Manual for that machine.
  #15   Ban this user!
Old 03-31-2011, 01:04 PM
jorber's Avatar
George
After solve the problem with the marker for the X axis. we have been using the machine.
but, the machine have a jump on the Z axis every 1" starting from the z home position point.
I test everything and found that the problem is on the controller (not the motor, encoder, driver or ballscrew), I changed some parameter related with Z axis but nothing change, what do you think that could be the problem? could be the board?
Need Help!- Bridgeport CNC Torq-Cut 22, need advise Barney General Metal Working Machines 2 04-07-2009 06:42 PM
Bridgeport torq cut-22 problems!! baystard Bridgeport and Hardinge Mills 15 01-17-2008 01:22 PM
bridgeport torq cut 30 software jaimeeduardo Bridgeport and Hardinge Mills 9 09-25-2007 09:52 PM
bridgeport torq cut 30 shot pin porkchop21 Bridgeport and Hardinge Mills 2 08-08-2007 11:21 AM
Bridgeport Torq-Cut 2G-????? bherr Bridgeport and Hardinge Mills 17 10-21-2006 12:56 AM
