Old 02-15-2009, 05:16 PM
fireguy976 is on a distinguished road
Cleaning up a grungy old machine
Greetings all,
I just picked up an old series I bridgeport mill. (my first ever, so call me a virgin,, I can take it)
Its quite filthy, and much of the paint is chipping off. Id like to give it a nice make over before I slide it in place.
If anyone has done this, would love some advice on this please.
Thanks,
Ken J
Old 02-15-2009, 05:32 PM
Al_The_Man's Avatar
If it is in that of a state, it probably has not seen much maintenance
So first I would take care of the mechanical condition before the cosmetics.
Like completely flush the lube lines and clean the lube pump and replace the oil metering devices, if it has these.
For cleaning, try the cheap way first, while you have everything apart, try Varsol. if this does not work, you may have to try a Automotive Pre-wash, available at automotive paint stores.
Use a good quality paint, Tremclad is one of the cheapest.
Old 02-15-2009, 05:53 PM
KIMFAB's Avatar
KIMFAB is on a distinguished road
I've had good luck with a citrus based heavy duty professional cleaner from Ace hardware #1013325. The grease is easy it's that mist coolant stuff that is hard to remove. When cleaning the ways do as good a job as possible, remove the wipers, then move to one limit and clean again, move to other limit and clean again.
I then use Marvel Mystery oil or any high detergent light oil. Prime the ways, move to the other limit, prime again and keep going till it wipes clean, then work the way oil in in the same manner. As for the paint Acetone and Lacquer thinner will remove almost anything (including the oil in your hands, careful). I like to repaint with an epoxy base paint. Again be very careful the good stuff is a cyanide base, do it outside with a slight breeze, very toxic. Of course the best way is to completely disassemble.
I used to be appalled, now I'm just amused.
Cleaning Tapers Hydronaut General Metal Working Machines 0 01-06-2009 07:18 PM
Cleaning a new X2 tooManyHobbies Benchtop Machines 4 04-21-2008 02:30 PM
Cleaning Question chevdrgtrk Bridgeport and Hardinge Mills 11 08-18-2007 10:32 AM
Cleaning of Ballscrews zoeper Linear and Rotary Motion 4 08-08-2006 02:52 PM
End PCB cleaning drudgery MrWild General Electronics Discussion 6 11-13-2005 01:18 AM
