Old 02-14-2009, 05:11 PM
RP Designs is on a distinguished road
Bridgeport series 2-opinions and info needed
I am looking at a Bridgeport series 2 CNC mill but I don't know much about them. It looks to have a decent work envelope 30x15x5 in in the x,y and z respectively, but I don't see if it has additional knee travel as well. I like that it is a closed loop system although it is an older mill (1983 vintage).
Can anyone give me some feedback on this mill. Are there any known problems with this particular machine? Are parts readily available? What are the things I should know and what are the going prices for this particular machine? Thanks in advance.
Old 02-15-2009, 01:16 PM
gus gus is offline
gus is on a distinguished road
re
what machine is closed loop from 1983?
The SII is some great iron, the knee travels as in the SI, but I think air assisted
Old 02-15-2009, 01:43 PM
This is the info from the description:
"Closed Loop w/ Encoder Feedback"
Here's the complete specifications from the ad:
Big Travels X - 30", Y - 15", Z - 5"
60-4200 Rpm VariSpeed, 2HP (1.5Kw)
X & Y Axis Rigid Boxed Way Design
Universal QS200 or Erickson #30 Spindle
250 IPM Max Rapid Traverse
.1- 100 IPM Cutting Feed Rate
10-120% Feed Rate Override w/ Hold
Continuous Jog Rate 150 IPM all Axes
Increment Step & Jog Handwheel Modes
G-Code Programming w/ Canned Cycles
Both Mist & Flood Coolant Outputs
RS232 Serial Port w/ DNC Software
12Kb Battery Backed Program Memory
2 x 16 LCD Display
Powerful 40 lb/in DC Servo Motors
Servo/Input Resolution .0001"
Positioning Accuracy - .0008" / Repeatability .0003"
Bijur Auto Central Lube System
Air Requirements 4 CFM @ 100 PSI
Power 208-230v (3Phase Only) / 30Amp Service
Air Assisted Manual Knee & Special Dual Knee Locks
Table Workpiece Capacity 1000 lbs.
Floor Area 92" x 97"
Height 89"
Shipping Weight 5000 lbs.
Now, I am very new to this and only have a little bit of CNC experience on some 3 axis BP's at school. I have been leaning towards something like the Tormach mill but I have run across some knee mills which are selling for decent prices. My concerns are the age of the machine (more for the controls than the mechanicals) and whether or not it is worth it. If it is a true closed loop system (which I am skeptical about given the age) it may be worth it, but again I think my ignorance makes it difficult to make an informed decision.
Old 02-15-2009, 06:08 PM
Moderator
machintek is on a distinguished road
the 2 line LCD means that it is a R2E3 BOSS8. The 15 inch Y means it is a series 2.
George
Old 02-16-2009, 01:29 PM
Yes, but given the machines age is this a good machine to buy? Will I need to upgrade the control? Will parts fail frequently? Are there replacements readily available? Is buying this mill better than something like a hobbyist machine (i.e. Tormach etc)?
Old 02-16-2009, 07:22 PM
gus gus is offline
machinetek can best respond to the reliability of the control, but the basic iron and servo system is a pretty good package, and the series 2 is a pretty beefy machine. Not bad
On the other hand, VMC's can be had in the 10k range these days....
Old 02-19-2009, 02:57 PM
anyone else have any info or feedback to offer?
Old 02-19-2009, 07:44 PM
Jim Bass is on a distinguished road
All I can offer is my experience, I have a BOSS 8 with stock controls. Have owned it for about five years. It just keeps cranking out parts. I have never had one single problem. I run it three to four times a week in the evening.
Where I work we have a Bridgeport V2XT that I operate. In fifteen years at 40 hours a week it has had one loose electrical connection that took a little effort to find and fix.
Jim
Old 02-19-2009, 08:51 PM
tpmx57 is on a distinguished road
BP Series II
I have a Series II and am running Mach 3 with one of Dereks breakout boards.
I am very happy as far as how solid the machine is.
The travel of the series 2 is a plus.
Other than twice blowing transistors the machine has been perfect.
You would be happy with it.
Old 02-20-2009, 12:55 AM
Cna you tell me more about your set-up with mach3? What is the cost and is it pretty straight forward. One thing I would like is to be able to add a fourth axis so I might have to change the control anyway.
  #11   Ban this user!
Old 02-23-2009, 08:21 PM
hmc710 is on a distinguished road
Series II
We've been running one for a couple years now with TNC145 control. Machine is what it is, great by 1980's stds, old but worthy, in my opinion, today. Comes down to price and use, if you are comparing it to hand machining, it great. If you are bidding on a large order, do your homework. Its been a great first cnc machine for us.
  #12   Ban this user!
Old 02-24-2009, 12:50 AM
zafarsalam is on a distinguished road
I bought Series II interact 2 some 3 years ago. Ran it on TNC145 control till 5 months ago when I changed it with Mach3 and AC servo motors. The old control was working fine. Switchover was because I needed 3d contouring and bigger gcode files on it. Otherwise TNC145 and original DC servo motors were running perfectly. It's mechanical structure is in excellent condition for a machine dated 1985-86 or so. After switching to Mach3, I am thinking why didn't I do it earlier. Productivity of the machine has increased remarkably due to Mach3. I am putting together a 4th axis these days for this machine.
Zafar
Need Help!- bridgeport boss series maintenance manual needed for z axis timing belt change ajitsingh Bridgeport and Hardinge Mills 0 11-06-2008 10:57 AM
Bridgeport Series II Info TPMX Bridgeport and Hardinge Mills 5 01-27-2007 07:56 PM
Bridgeport Series II R2E4 tech needed beaver Bridgeport and Hardinge Mills 1 09-27-2006 06:55 PM
Bridgeport Series 1 CNC w/ BOSS 5 serial cable needed bbuonomo Machine Problems, Solutions , Wireless DNC, serial port 16 05-30-2005 06:05 AM
New here... Opinions needed Brass_Machine General Metal Working Machines 5 11-08-2004 10:48 AM
