Old 02-14-2009, 02:15 PM
Jurek is on a distinguished road
INT 412 Y Axis Overloaded
My 87 INT 412 with 151 Cntr shows the message : Y axis oveloded and shuts down. Check brushes in the motor/ they look good/ table move freely by hand / lubrication ok, called Heidenhain,they said it is Bridgeport message .Can not find in the maintnance manual. Any suggestion please. Machine has a very litlle use. In Last 20 years it was working maybe 2years single shift short production and prototype alum and plastic parts.Thanks .Jurek
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
412 Y axis overloaded Jurek Bridgeport and Hardinge Mills 1 01-03-2009 03:55 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
