Old 02-10-2009, 06:55 PM
HimyKabibble is on a distinguished road
Quill Drive Reduction
I'm about to build a quill drive for my BP clone. I'll be using a 5/8" 5-pitch ballscrew, and probably a stepper motor. I have the impression most people use rather large steppers (800-1200 oz-in), and 2:1 or better belt reducers. Problem is, I can't for the life of me see the need to any reduction on there. I'd like to get 150 IPM, which would be 750 RPM at the motor, with no reduction, which is a reasonable max RPM for a stepper. In terms of force, it appears to me direct drive would also give me upwards of 500 pounds on the quill at cutting speeds, using even a large NEMA23 motor, and I can't imagine I'd need more than that.
So, question is, what size (oz-in or N-cm) motors are you guys using, and with what, if any, reduction?
Regards,
Ray L.
Old 02-10-2009, 08:25 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
I used the Elrod conversion and it was sent and I installed it with 1:1 pullies. I used 2:1 on the table and didn't power the knee. I heard 4:1 on the knee.
Old 02-10-2009, 09:57 PM
Do you happen to know the motor torque rating? Or rated voltage/current? Or make/model?
Regards,
Ray L.
Old 02-10-2009, 11:40 PM
supposed to be 1800 oz/in, I think not, but they are Pacific Scientific servo's 48v power supply and 20 amps using Gecko 320's.
Old 02-10-2009, 11:43 PM
And the Elrod conversion doesn't come with the servo's. Comes with everything but the servo or stepper, I think it came with a nema 23 mounting plate, but I had to make a new one because my servo's don't have Nema mounting plates, they are just round with 4 blind mounting holes in the front.
Old 02-10-2009, 11:54 PM
NEMA23 suggests the intended motor torque was no more than about 600 oz-in, which seems reasonable to me.
Regards,
Ray L.
Help with BP J-head CNC quill drive titchener Bridgeport and Hardinge Mills 7 12-28-2008 05:16 PM
automatic idle-current reduction & belt drive ?? Georg DIY-CNC Router Table Machines 1 11-06-2007 03:11 PM
Rack and Pinion Drive / Gear Reduction captainkirk DIY-CNC Router Table Machines 5 09-22-2007 07:19 PM
Direct or geared reduction to threaded drive ? (stepper) andy_ck87028 Linear and Rotary Motion 4 03-13-2006 07:42 PM
Direct drive vs. Belt Reduction - Mini Mill Conversion sanddrag Benchtop Machines 2 02-10-2006 10:00 AM
