Hi, Machine is a Bridgeport Interact 1 Mk2. Have Installed replacement Y-axis servo motor which I believe is wired correctly but upon powering up the machine and pressing the orange power button, the Large fuse (MF1) blows instantly. The trip switch for the 3 phase plug point goes also. Would incorrect wiring cause this or is there something inside the motor shorting maybe? Any help appreciated, more info available if required. Many thanks |
| Try with the motor disconnected, If they still blow it is probably not the motor. Al.
| SEM is, or was a UK company. Either partially dismantle the motor and check the condition of the brushes and commutator and colouration of the windings to see if there is anything obvious that can be fixed, the alternative may be to take it to a motor rebuilder and get them to check it out. If you opt to repair it yourself, it can be tested on an automotive battery before putting back in place. Al.
| SEM is Small Electric Motors of the UK. Google and see what comes up on that side of the pond. Pull out a brush and give it a sniff test. If it smells burnt, it probably is. George
| Blowing Z axis fuses on 6MB | moldmker | Fanuc | 13 | 08-29-2008 11:34 PM |
| X-Axis Blowing fuses | Thom45 | Commercial CNC Wood Routers | 0 | 02-21-2007 01:33 PM |
| Blowing fuses | kaderick | General Electronics Discussion | 2 | 12-05-2006 11:34 AM |
| Blowing the fuses | rocks101 | Hobbycnc (Products) | 2 | 02-26-2005 03:00 AM |
| Motor tuning and Blowing fuses | DAB_Design | Gecko Drives | 0 | 11-01-2004 07:10 PM |
